Old 11-26-2007, 09:03 PM   #1
tcb-1
Nothing to see here.....
tcb-1's Avatar
How low with front drop springs while keeping alignment????
how low can I go with front springs while still being able to maintain frontend alignment? I have new rubber up front and I don't want to scrub them down.
I have 2.5 drop springs on it now, but want to go bit lower.
I know I can go with spindles, but my 69 stepside is being built on a budget.
thanks for any ideas.
tcb-1 is offline   Reply With Quote
Old 11-26-2007, 09:18 PM   #2
Boog
laying low
Boog's Avatar
Re: How low with front drop springs while keeping alignment????
If you've already got 2 1/2" drop springs on the front your best bet will most likely be dropped spindles to give you about 5" total. However since you have 15 x 10" rims and wide tires on front you might have some clearance issues to consider. The spindles will push each wheel out about 3/4" further. Someone else will post what they have experienced I'm sure.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 11-26-2007, 09:28 PM   #3
tcb-1
tcb-1's Avatar
boog,
I could go with spindles, but I am maxed out fund wise. I'd love to get spindles up front, but then I'll have to go discs.
I actually have quite a bit more clearance I could drop the front. probably have close to 4".
this is a wierd truck. I have 5" drop springs on the back, but it doesn't drop it nearly as much as other trucks that run a 5" drop. actually, it's about a 3" drop...... just don't understand.
but I digress..
any ideas on my frontend?
Old 11-26-2007, 09:56 PM   #4
Boog
laying low
Boog's Avatar
That truck sure sits up "normal" like to have dropped springs on it. Well, as much as I dislike the idea of cutting springs, you could cut 1 coil off the front springs and get a couple more inches of drop up there. As for the rear, no cutting. You will have to install say a 2" lowering block to get it down some or buy more springs. You're running 10" wheels and 275/60 tires all round right?
Boog
primer is finer
Old 11-26-2007, 10:02 PM   #5
tcb-1
tcb-1's Avatar
well, that's my plan is to wack about an 1.5" off the front. I'm then going to go with some 2" drop blocks from CPP for the rear, just like your suggestion.
but I'm just concerned about if I do go 1.5" lower, the frontend won't align.
yes, I am running 15 x 10's with 275/60/15 at all four corners......
Old 11-26-2007, 10:12 PM   #6
Boog
laying low
Boog's Avatar
Sounds good. Do some more reading on this. I'm not sure just how much drop you get per coil cut off. Removing 1 coil may be just enough and it may not. If you end up with more drop than an alignment can fix you can always pickup some more coils to put it back. If you get 4" of spring drop I think your bump stops will be close to the frame won't they? Bottomed out?
Boog
primer is finer
Old 11-26-2007, 10:22 PM   #7
tcb-1
tcb-1's Avatar
as right now, I am 3" off the bump stops up front. so, I'm thinking to go half of that and I'm gold.
just paranoid about ruining new rubber.
Old 11-27-2007, 04:39 AM   #8
68shortfleet
If i were cutting your coils, I would only cut about 3/4 of one coil and reinstall to check the height. Drive it a few miles before checking the height. I would bet that 3/4 of one coil will drop the front about 1-1 1/4". You are getting very borderline on alignment at that point(usually). Look at upper control arm mounting bolts/nuts. How much thread is still not being used? The alignment shop will need about another 1/4" of thread to shim the upper arm back out when you lower it more.
HTH
Jason
68shortfleet is offline   Reply With Quote
Old 11-27-2007, 05:50 AM   #9
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
My truck is has 4 inches of spring drop in the front (along with my spindles). I'm right at the limit of aligning it. I'm out of upper control arm bolt room and my camber is still about 1/4 degree negative.
When I had just 3 nch drop springs,it aligned fine.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 11-27-2007, 07:20 AM   #10
70GMCer
70GMCer's Avatar
Ask 70c10 about this. He did this and alignment is way out now. He knows how much coil cut he did along with his 2 1/2 drop spindles.
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 11-27-2007, 07:42 AM   #11
Tx Firefighter is right at the limit with 4",as he said.3" is good and safe for allowing more adjustment,if needed and alignment guys won`t scwabble and whine.
Old 11-27-2007, 11:30 AM   #12
piecesparts
Parts and more parts
piecesparts's Avatar
Originally Posted by Tx Firefighter View Post
My truck is has 4 inches of spring dropin the drop (along with my spindles). I'm right at the limit of aligning it. I'm out of upper control arm bolt room and my camber is still about 1/4 degree negative.
I am putting the CPP tubular control arms on my 68 and that will be along with a 2 1/2" drop spring and drop spindles. The tubular arms are set with the camber changed to make up for the the lower setting and allow further wheel adjustment, when lowering. I am hoping that I will be able ot align when I am done.
Old 11-27-2007, 11:34 AM   #13
Tx Firefighter
You can align a 3 inch spring with stock arms, so with your expensive aftermarket arms, I'm sure you won't have any trouble with just a 2 1/2 inch spring..
Old 11-27-2007, 01:37 PM   #14
Robznob11
Robznob11's Avatar
im shure if you relly wanted to you could replace those a arm bolts with some longer grade 8 hardware in a fine thread and it would be cheaper than upper tubular arms, if your gonna get tubulars id suggest performance suspension online they are 3/8 longer arms with adjusted camber just for lowered springs
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride!
........................ ___
.........________//__{\_____
,,,,,,,/__(⊙)___//___/__(O)_/
@disciple2.rc 💪instagram💪
LED TAILS
Robznob11 is offline   Reply With Quote
Old 11-27-2007, 07:07 PM   #15
71 lowrider
If you cut 1 full coil from a stock spring,you will drop the truck 3". I have done 4 or 5 of them,and they all dropped about that amount. You will have to cut off the bump stop brackets,and put bump stops directly on the lower control arms.I have never had any problem aligning these trucks,but if you drop too far the angle of the upper balljoint stud gets pretty steep.The stud could bind up and snap off.
71 lowrider is offline   Reply With Quote
