Old 11-27-2007, 03:22 PM   #1
bfink
Question master cyl. mounting ?
for those of you who kept your m/c in the stock location under the floor(ive got a 55.5 )what kind of master cyl did you use and how did you mount it? . my truck has a 78 camaro clip and ford 9" that i just put some wilwood disc's on. the truck currently has a single res. master on it . i dont plan on using a booster and i want to keep the stock pedels coming up throung the floor , any suggestions? thanks , Brian
bfink is offline   Reply With Quote
Old 11-27-2007, 06:24 PM   #2
entourageguy
Yellow truck club
entourageguy's Avatar
Re: master cyl. mounting ?
Check out CPP http://classicperform.com/
or Brothers. Both have kits for using the original brakes.
I think you need a dual res. if running discs.
Brian ...
ps
Brian ......
My hub garage address
http://www.hubgarage.com/mygarage/59apache
I gue$$ everything has it'$ price
ALL GONE NOW
59 Chev Apache
PRAISE THE LOWERED
350 700r lokar shifter
power MII front end, shockwaves
tilt, 4 wheel discs
4-link and bags
10 bolt limited
entourageguy is offline   Reply With Quote
Old 11-27-2007, 08:42 PM   #3
brianthelion02
Overdrive club
brianthelion02's Avatar
I used the cpp master and booster assembly,very straight forward mounting and since i was running all new metal brake lines anyway that was n/p!!!!!And othere than crawlin under the truck and physically seein it it all looks stock,including the pedal!!!!!!!!
1971 c-10
1951 3100 chevy
1970 chevy c-30 Sold!
brianthelion02 is offline   Reply With Quote
Old 11-27-2007, 10:34 PM   #4
CAL 58 GMC
CAL 58 GMC's Avatar
I used TCI's kit that bolted up to the stock location.
CAL 58 GMC is offline   Reply With Quote
Old 11-27-2007, 11:25 PM   #5
1-ton of fun
polishing a turd
1-ton of fun's Avatar
tci's kit looks the best, (strongest) i like the triangulation on the bracket
59 chevy apache 31 4x4 - my project: http://67-72chevytrucks.com/vboard/s....php?p=8668512
53 buick special - straight 8 sled - blow through turbo
47 gmc - flatbed hot rod build
99 ford econoline e350 - 4x4 converted family roadtrip/overlanding rig AKA 'Monstervan' AKA 'Daddy-Van'
1-ton of fun is offline   Reply With Quote
