Old 11-28-2007, 12:20 PM   #1
harley
Instrument bezel question
Eventually I want to swap out the stock guages on my '63 for a cluster of new ones. I've not taken out the original cluster to see how it all attatches to the bezel and was wondering if the bezel seperates from them or is there some cutting involved
If you have pics of how you made the swap I'd like to see them.
'63 Short Fleetside
http://gallery.mac.com/gracpogue#100044
harley is offline   Reply With Quote
Old 11-28-2007, 12:44 PM   #2
Tim64
Tim64's Avatar
Re: Instrument bezel question
As far as I can tell it's a one piece unit.
Tim64 is offline   Reply With Quote
Old 11-28-2007, 12:48 PM   #3
mbgmike
It should all come apart with a the lens,bezel, and gauges seperate.
mbgmike is offline   Reply With Quote
Old 11-28-2007, 12:50 PM   #4
fuelpump
fuelpump's Avatar
On the same subject how do you remove the plexiglass???
fuelpump is offline   Reply With Quote
Old 11-28-2007, 01:28 PM   #5
harley
That's what I was hoping for.
So then all is needed is to attatch a piece of aluminum or whatever and drill for the new guages right?
'63 Short Fleetside
Old 11-28-2007, 01:44 PM   #6
David Flores
David Flores's Avatar
Correct.
66 c10 swbfs
My Build.
David Flores is offline   Reply With Quote
Old 11-28-2007, 01:53 PM   #7
David Flores
Here is how it is put together.
For what you want to do, just take out the old gauges.
Trace the plexi glass onto some aluminum and cut it out, then drill holes for your gauges. Then you should be able to get rid on the plexiglass and the glass aluminun piece that is in there now. Then just put it back together.
66 c10 swbfs
My Build.
Old 11-28-2007, 01:58 PM   #8
harley
That's exactly what I was looking for. Looks like an easy swap.
Thanks.
'63 Short Fleetside
Old 11-28-2007, 02:33 PM   #9
NF65Fleetside
NF65Fleetside's Avatar
yah, Im planning on just making an aluminum sheet to house 5 autometer guages. Going to gut the stock housing to accomidate the aftermarket guages and use the plexi glas and bezel to complete it.
NF65Fleetside is offline   Reply With Quote
Old 11-28-2007, 03:13 PM   #10
Tim64
Tim64's Avatar
The one David has pictured is a 64'-66'. Do the 60'-63' come apart the same way? I have seen bezels and glass advertised for the 64'-66', but never for the 60'-63'. I have seen complete ones for sale.
Old 11-28-2007, 04:54 PM   #11
slepysal
slepysal's Avatar
Yes there basicly all the same . Here is my "El Cheepo" guages
http://67-72chevytrucks.com/vboard/s...ghlight=GAUGES
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes.
"Over, Around or through it... "
slepysal is offline   Reply With Quote
Old 11-28-2007, 05:11 PM   #12
harley
Nice "How To" post.
I have the same 3 Sunpro guages hanging under the dash now, following your suggestion I could do this swap even cheaper
'63 Short Fleetside
Old 11-28-2007, 07:03 PM   #13
NF65Fleetside
daym Sal! You tha man! exactly what I wanted to do, thanks for sharing that.
Old 12-01-2007, 07:44 AM   #14
Greg63
Enjoy your truck
Greg63's Avatar
Here are the gauges from my '63 .
I added the vacuum gauge from an early '60's Pontiac , the tach is 60's Sun unit and the temp gauge is a Sunpro that I modified to fit in the stock location .
There is a little bit of work involved in the cluster removal (I must have had mine out 20 times over the last 26 years), but it is really easy to accomplish .
Greg
1 Corinthians 10:13
1963 Chevrolet 1/2 ton
2010 Camaro SS/RS
2014 Jeep Grand Cherokee
2016 Jeep Cherokee
Greg63 is offline   Reply With Quote
Old 12-01-2007, 11:00 AM   #15
harley
Please define "work"
I started to remove mine just to see what all was involved. Well, it sure does not want to just slide out. I stopped 'cuz I am not quite ready for the swap.
Looks like other parts may need to be removed to get it out.
'63 Short Fleetside
Old 12-01-2007, 12:19 PM   #16
Greg63
Enjoy your truck
Greg63's Avatar
When I have taken mine out , I remove the 5 or 6 bezel screws and slide it (with some effort) slightly forward from it's home in the dash . Then I can reach under the dash and up to the speedo cable and unscrew that . Then I can pull it forward farther and disconnect all the wiring from the back of the cluster . At that point it is free to be removed .
If you have the cluster with the gauges (not idiot lights), you will need to undo the oil pressure tubing . That is the only mechanical connection outside of the speedo cable (if you are really fortunate you will have a vacuum hose going to your vacuum gauge , but those clusters are pretty scarce).
Work is involved , but it is pretty easy work .
Greg
1 Corinthians 10:13
2010 Camaro SS/RS
2016 Jeep Cherokee
Old 12-01-2007, 01:34 PM   #17
harley
I see what you mean. At this time I have a 3 guage cluster mounted under the dash so the only working parts are the speedo and fuel and the headlight lamp.
Thanks for the "how to". I really appreciate it
'63 Short Fleetside
