Enjoy your truck
polishing stainless trim
I have just picked up a set of '63 - '66 stainless side trim for the truck and now I want to clean and polish it . I have read various articles about polishing , but I want advice from anyone who has done it to one of our trucks .
I have practiced on a piece of door trim (lower) that I had laying around . It seems that there is some type of a "coating" that is coming off when I put pressure on it . It is really shiny when the coating comes off , but I fear I may be doing something wrong . You really have to hold it on the wheel and put pressure on it to get this result . I do not want to screw up the pieces I just got . I am using a 6" bench grinder with sewn cotton wheels and black and green compound . Can anyone add some advice or direction ? Greg
1 Corinthians 10:13 1963 Chevrolet 1/2 ton 2010 Camaro SS/RS 2014 Jeep Grand Cherokee 2016 Jeep Cherokee |
65 - Chevy C10
Re: polishing stainless trim
I heard that hitting them with some oven cleaner before polish can do some wonders. test a piece out first. let it soak for like 5-10 minutes.
Enjoy your truck
I have never heard of that before .
I will try that today and see how it goes . Any other tips anyone ? Greg
yes, i do
i saw the oven cleaner trick on an episode on trucks i think. can't remember the polish that they used though
ERROR 404....... SNAPPY COMEBACK NOT FOUND ![]() _______________________________________________________________________________________________ -60 Chevy C10, dead 350/good th350 combo, sitting on a 76 c10 blazer frame, built from 11 different vehicles "the abomination" -07 gmt900 silverado 1500 lt xcab z71, granite blue -81 suzuki gs650g "shelah"- current project -81 kz1000m1 csr "sarge" -next project (just beautification) -07 kawasaki vulcan classic vn900 |
Sounds like that door trim may have a clear coat of some kind on it and you are just "burning through" it
Enjoy your truck
That is what it seems like , but I was not aware of a "clear coat" on trim for the '60's .
65 - Chevy C10
i believe its anodized coating. This is what the oven cleaner is removing.
Enjoy your truck
If that is the case , am I damaging anything by doing that ?
65 - Chevy C10
If it looks crappy with it, then whats to damage? You are just removing old beat up anodized coating and polishing up what you have.
Enjoy your truck
Good point .
Truck Parts Mfg.
![]() Join Date: Jul 2005
Greg63: I believe the moldings are aluminum not stainless. The coating you are removing is the anodized surface of the aluminum. Once you cut through the anodize surface the soft aluminum remaining is easily polished to a bright luster. As you have found, this is a lot of work and difficult to accomplish with uniform results. The polished aluminum will not be as durable without the anodized surface and will likely become dull from exposure to the elements. Also, it will be much more easily scratched and scuffed if left without anodizing.
If you have a company locally that does anodizing of aluminum, they can chemically remove the anodize surface so you can repair and polish the parts. The parts can be then anodized again to protect the bright polish. If you do this, be sure the company is equipped to process bright aluminum. It would be good to have them anodize your "practice" door molding first to make sure that you are satisfied with the results. An alternative method of protecting the moldings after polishing is to coat them with a clear coat paint. Glisten by POR 15 works well for this and has good adhesion even to polished aluminum. It is not as durable as anodizing, but may work well for moldings that are usually protected from the elements. As with anodizing, it is recommended that you use your practice door molding to make sure your procedure gives the results you are looking for. Be especially careful assembling the front fender spear tip to the fender molding to avoid scratching through the coating. Mar-Ktech
GET MAR-K Quality! Restoration and Custom Pickup Parts for Chevy, GMC, Ford, Dodge and Custom Trucks |
#12 | |
Enjoy your truck
I am really glad I had a spare door piece to experiment on and not bugger up the "good" pieces . Thanks , Greg
![]() Join Date: Nov 2007
2000 grit sandpaper also works, the finer the better!
Enjoy your truck
Well , I am about 3/4 of the way through the job and the results are amazing .
I soak the trim with oven cleaner for around 45 minutes and then hit them with an S.O.S. pad . In most cases the anodizing comes right off , but sometimes a second run through with the oven cleaner is needed . At that point I can push out and file down any dents or surface imperfections . Once they are down to raw aluminum and straight it is easy to buff them up . I will give them a clear coat to protect them once they are all finished .
#15 |
Glad to hear this method is working. I have toyed with the idea since I saw it on Trucks several months ago. I have a great deal of factory trim and Custom Cab sails from '60-'66 Chevy trucks that could use some attention. Please keep us posted with your progress and pictures. Thanks for your efforts.
#16 |
you got any pics of how it looks befor and after?
ridin big yo 5in cpp lowerin springs in back lowered 3in in front with cut springs for now 5 lug swap and disk in front 5 lug and disk in the rear with 3.23 gears mild 350/400heads 7547weiand intake 600 Edelbrock chrome block hugger headers 2 1/2 pipes in to a x pipes super 40 flows and turn downs turbo 350 with shift kit |
#17 |
Enjoy your truck
I kick myself for not taking any pictures before because these pieces were rough . I don't mean junk rough , but each piece needed to be straightened out one way or another .
I can certainly post after pictures .
#18 |
kool
#19 |
Enjoy your truck
Here are a couple of sample pics .
The wide piece has been filed in some area's , but you can see the finish on it . The thin piece has been completed (except for clear coat) . Please excuse the greasy fingerprints . ![]() ![]()
#20 |
http://www.caswellplating.com/buffs/buffman.htm
I am not an agent for this company, nor am I selling anything. I purely offer this link as a resource I have forund helpful.
1963 Chevrolet C-10 "Ginger" ![]() 1970 C-30 Dump Truck "Scarlet" 2019 Chevy Silverado 2500 Z71 LTZ 1947 Indian Chief Roadmaster with Sidecar. 2012 Indian Chief Serial #002 of 110 built in '12 2016 Indian Chief Roadmaster Last edited by Micmac; 01-26-2008 at 12:33 PM. Reason: correct spelling |
#21 |
65 suburban vortec 5.3 bagged
i second this Micmac that caswell place is awesome!!! i have bought a bunch of stuff from them and they are very helpful and know there product they are about 20 miniutes away from me great place!!
#22 |
Enjoy your truck
Well, I have got all the pieces straightened out and installed on the truck.
Considering what they looked like prior to my efforts, they don't look too bad. I will get some pictures up shortly. I was unable to get one of the front fender pieces sorted out though. It has about 200 small pits in it. Does anyone know where I could get a good used fender trim piece? (the long one, not the end spear) A new piece would stand out next to my refurbished used pieces. Greg
#23 |
Enjoy your truck
Here are a couple of pictures from the drivers side;
#24 |
WOW!! looks nice!!
#25 |
60-66 Nut
Good job on the trim....Very nice '63
![]() I have never seen those type of wheels before...what brand are they?
