12-01-2007, 08:14 PM | #1 |
lower springs - not even
I put on lowered spindles and 2 1/2 inch lower springs in the front and 6 in the back. Got it aligned etc... and it rides great but I notice front passenger side is about a half inch higher (just eyeballing).
Any suggestions? Last edited by Mondo; 12-02-2007 at 05:16 PM. |
12-01-2007, 08:24 PM | #2 |
Re: lower springs - not even
are the pigtails in the springs seated correctly on the arms? Just a thought...
12-01-2007, 08:25 PM | #3 |
Maybe the body mounts are worn?
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD Click here to support the board Philippians 4: 6-7 |
12-01-2007, 09:02 PM | #4 |
yeah, I'm hoping it's just the spring got twisted when they put on the spindles.. I just haven't got a chance to look but figured I check more than one thing at that time if I got some other suggestions to look at.
cab was off a couple years ago- new mounts, don't think their worn out that fast Does the rear have springs seats like the front too? |
12-01-2007, 10:57 PM | #5 |
"Trucks with Class"
Remember, the left side of the truck is heavier than the right: steering col/wheel, box, pump, alt...
Be sure the frame is actually lower, not just the body. If you think you have a weak spring, you can test them by reversing them...a little work, but then the truck should be low on the other side. |
12-01-2007, 11:33 PM | #6 |
if it is belltec parts they offer a spacer for the driver side to level it up if you look at any chevy or gmc truck thats been static droped they all lean that way
12-02-2007, 07:15 AM | #7 |
67-72 Addict!
I recently cut a pair of front springs and the driver side sits a little lower. When I get in it's even more noticeable due to my weight. I bought a set of coil spring spacers that twist into the coils and plan to raise the driver side almost a half inch to make it level while I'm driving. I'm picky about the stance and the spacers were only $5 at the local parts store and look like this. Pickmup's way is the best but I'm too lazy and figure these are worth a try.
http://sports-imports.stores.yahoo.net/twinspbo.html
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads Last edited by 70c10; 12-02-2007 at 07:27 AM. |
12-02-2007, 05:16 PM | #8 |
Thanks guys! Nice to know it wasn't something I did... Too bad I like the lower side better than the raised side
Looks like 3" lower springs will be ordered next... Last edited by Mondo; 12-02-2007 at 05:16 PM. |
