Old 12-02-2007, 01:08 PM   #1
jorgensensc
jorgensensc's Avatar
What Hitch is better?
I am looking at ECE's hidden hitch and CPP's hidden hitch. Which one have y'all used and which one would you suggest. CPP's is cheaper and appears to mount differently. Thanks ahead of time!
Shawn
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 12-02-2007, 01:20 PM   #2
NONHOG
NONHOG's Avatar
Re: What Hitch is better?
If you don't mind i'd like to add which works with Blazer tanks ? THANKS
"I feel the need for speed!"... as soon as I am done with my nap.
NONHOG is offline   Reply With Quote
Old 12-02-2007, 04:30 PM   #3
jorgensensc
Good point, I forgot about that. i have a blazer tank also. Thanks for mentioning it!
Shawn
Old 12-02-2007, 09:33 PM   #4
jorgensensc
Looking for some input.
Old 12-02-2007, 09:47 PM   #5
brak
brak's Avatar
Rokcrln was raving about the one from ECE if i recall correctly.
His reccomendation is good enough for me
2003 GMC Sierra 1500 WT
1995 Nissan Hardbody
2016 Hyundai Veloster Turbo
DC2 (SW/AW) Clyde W. Harvey USN
"Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery" Winston Churchill
brak is offline   Reply With Quote
Old 12-02-2007, 10:05 PM   #6
Hart_Rod
Hart_Rod's Avatar
I've got an ECE one on my suburban and one on my CrewCab. Both are very well built. You should not have a problem with your tank. You can check out either of my build links for pictures.
R
Hart_Rod is offline   Reply With Quote
Old 12-02-2007, 10:32 PM   #7
jorgensensc
Who made yours?
Originally Posted by Hart_Rod View Post
I've got one on my suburban and one on my CrewCab. Both are very well built. You should not have a problem with your tank. You can check out either of my build links for pictures.
R
Old 12-02-2007, 10:47 PM   #8
Hart_Rod
Hart_Rod's Avatar
Ece
Old 12-03-2007, 01:38 AM   #9
Rokcrln
Rokcrln's Avatar
Yes I have used ECE's hidden hitch and I have no complaints at all. I build with metal for a living and could build my own hitch in my sleep but after seeing ECE's awhile back I decided that theirs is just as good if not better then what I would do and much cheaper when you figure in steel prices, powder coat, mounting hardware, electrical hardware, drop hitch, lic plt flip kit and not to mention time! Here is mine before install and in use!
Kevin
LFD Inc.
Rokcrln is offline   Reply With Quote
Old 12-03-2007, 11:29 PM   #10
A.P.
Black 72 Chevy
A.P.'s Avatar
I've only used ECE hidden hitch and have no idea of CPP. I also have stock gas tank and the spare tire in the bottom of the truck bed. The ECE hidden hitch works great.
A.P.
72 Chevy, SWB, 350engine, TH400
A.P. is offline   Reply With Quote
