Old 12-06-2007, 05:20 PM   #1
crawdad
crawdad's Avatar
Pulling a travel trailer
I've got a travel trailer that weighs around 5500-6000 lbs. The other day I pulled it to a hunting lease in another state about 275 miles away. I had heard that I shouldn't pull in overdrive so I was pulling it in Drive. The road was hilly, but not all that bad. I noticed the truck getting pretty hot, especially on the hills. Seems like it was up around 210, sometimes higher, but it never did get in the Red. The engine RPM's were up there pretty high in Drive and I figured that might have something to do with it running so warm so I dropped it into Overdrive and the temp. went back down to just above normal. It normally runs right around 180 degrees. This truck was not originally set up for towing, but since I only pull the trailer about two or three times a year, I didn't think it would hurt it. My question is what can I do to keep the temp in the normal range and what can I do to the truck to make it a little more capable of pulling a load. I've already put a tranny cooler on it. I'm not sure what gears I have in the rearend, but I would suspect they're pretty high. Any comments appreciated.
2012 Silverado LT 1500, 5.3, 6 speed auto
'86 SWB C-10 Silverado
crawdad is offline   Reply With Quote
Old 12-06-2007, 05:44 PM   #2
chev74
Addicted to Chevy
chev74's Avatar
Re: Pulling a travel trailer
did you get the biggest tranny cooler they had?
can you get #s from your rear end so you can find out exactly what you have back there?
chev74 is offline   Reply With Quote
Old 12-06-2007, 06:45 PM   #3
spudz
spudz's Avatar
210 ECT?? or tranny temp? 210 is fine for ECT.....thats not hot at all. You better pull it in drive.. or you will be replacing that transmission.. Its going to run a little hotter because your working it harder.. its fine... Just don't pull it in overdrive.....ever lol
2004 z71, 96 z71 on 38s, 88 Chevy k5 blazer, 4in lift. 84 swb project, 82 SWB project , 84 chevy 4x4 lwb project, 88 Jimmy beater/highschool ride. 79 c30. 99 tahoe 4x4 project. and a bunch of parts trucks..
spudz is offline   Reply With Quote
Old 12-06-2007, 07:02 PM   #4
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
as long as you arent in the red youre fine the trans cooler is a good idea
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 12-06-2007, 08:30 PM   #5
crawdad
crawdad's Avatar
I'll climb under the truck tomorrow and see if I can find a tag on the rear end anywhere.
Old 12-06-2007, 08:32 PM   #6
crawdad
crawdad's Avatar
Yes, I'm talking about engine coolant temperature. It was between the 210 mark and the Red "Hot" zone. It didn't get any hotter than that. The tranny is the 700R4 BTW. I knew I should pull it in drive instead of OD, but I was getting concerned about the climbing temp.
BTW spudz, I just came through your neck of the woods the other day. I was coming from Charleston on 78 on my way back to GA.
Old 12-06-2007, 10:07 PM   #7
spudz
spudz's Avatar
You passed my house then cause I live right on 78 lol.. Ya passed a yellow house on right with a **** load of trucks and mustangs in the front yard in branchville?? lol
BTW you might want to make sure your clutch fan is ok... Maybe consider an electric fan??? It shouldn't run hot with a little more RPM...
Old 12-06-2007, 10:22 PM   #8
crawdad
crawdad's Avatar
I think the fan is ok, but I'll check it out to be sure. Thanks.
Old 12-06-2007, 11:25 PM   #9
68K20 x Drill
Consider the same engine in an 88 Camaro does not switch on the fan till 230F, you are fine. Water Wetter seems to help. if you had a Trans Temp gauge, I bet it would have up when you shifted to OD.
68 Chevrolet k20 Longbed 350 SM465/205, Dana 44, 14bolt, Power steering, Power Disk Brakes, 35" BFGs.
84 Chevrolet Suburban K20 6.2 Banks turbo TH400/NP208 Now with G80
68 GMC C20 Parts? Truck
And a few cars
68K20 x Drill is offline   Reply With Quote
Old 12-06-2007, 11:50 PM   #10
crawdad
crawdad's Avatar
Yea, I guess I was so used to the temp being around the 180 degree range that when it started rising like that I got a little concerned (maybe too concerned). I've heard of the water wetter and I think I might give it a try just to see what happens. Thanks.
Old 12-08-2007, 05:00 AM   #11
crossy
Oh,you can't buy that new
crossy's Avatar
no tag, there is a three letter code stamped in the right side tube usually dead on top, but sometimes more on front of tube. Like KTA, TUB, TGA etc. use a file and flashlight.
"been there, done that, ruined the T-shirt".
2007 LBZ GMC Sierra, ECSB
2006 LM7 RCSB Silverado
98 Vortec project.
94,3500,6.5L 4L80
81 SWB GMC POS finally gone
73 Pinto, stock, w/CragarSS's-eww
LOTS of Cummins trucks.
crossy is offline   Reply With Quote
