Old 12-07-2007, 10:46 PM   #1
sdkid
Front clip??? '89 burb
What did the grille of the 89 suburban look like. Any pics? A guy at work is looking at one out in the country. He wants it for the tbi. I am thinking of gettin whats left for the front clip. I thought they had the flat side by side headlights set-up, and the single light work truck set-up. I also saw one on ebay that had the older 1986 type grille with the headlights stacked. Did they do 3 different grilles in 89?
I think the world needs a drink...
Help somebody...If you can....VanZant
We're not wrong, we're not sorry, and its probably gonna happen again. That's the truth about men.
Tracy Byrd
Member# 13924
'70 c10, 350/350
'68 c10 250/4spd
'68 c10 no eng/trans fac ps/pb/ac/at
(future father/sons project)
'48 Chevy Loadmaster
sdkid is offline   Reply With Quote
Old 12-27-2007, 06:19 AM   #2
jkade
jkade's Avatar
Re: Front clip??? '89 burb
Should look like this if it is a gmc.
jkade is offline   Reply With Quote
Old 12-27-2007, 07:30 AM   #3
edman87
junk collector
Most looked like above pic, but there was a base work version with 1 larger sealed beam instead of the 2 small opes. The ones pictured above are getting harder to find and are not cheap!
'87/89/76 K5 in progress
'99 K2500 short crew
'91 camaro rs
'98 jeep tj
'52 willys cj3a
edman87 is offline   Reply With Quote
Old 12-27-2007, 07:35 PM   #4
Plumbnutz
Plumbnutz's Avatar
Here's a 89 K5. As long as it isn't the 1 headlight version it should look like this. I'm not aware of there being a 3rd grille.
74 K5 Blazer-built 350ci,Turbo 350, NP 205
8 lug Dana 44, GM Corp 14 bolt-4.56 gears, 37" Boggers
89 K5 Blazer-TBI 350, 700r4, NP 208
8 lug Dana 44, GM Corp 14 bolt-4.10 gears, 33" Toyo A/T
Plumbnutz is offline   Reply With Quote
Old 12-28-2007, 06:50 PM   #5
sdkid
I was told it looks like the 86 grille. It has the stacked headlights. He's sure of the year, and the grille style. I'm hoping it has the side by side lights. He just wants the tbi and 700r4. Maybe I can pick the body up cheap. I want the front clip. I guess I'll have to check it out for myself when he gets it.
Tracy Byrd
Member# 13924
'70 c10, 350/350
'68 c10 250/4spd
Old 12-29-2007, 03:52 AM   #6
Plumbnutz
Plumbnutz's Avatar
If this is true, so much for my assumption that the Burb had the same grille as the K5 in 89.
Old 12-29-2007, 12:59 PM   #7
sdkid
I thought it should look like the pics above too. I'll have to check it out for myself.
Tracy Byrd
Member# 13924
'70 c10, 350/350
'68 c10 250/4spd
Old 12-30-2007, 12:30 AM   #8
Mkcustums
Mkcustums's Avatar
They also offered these two styles as well. GMC version and the Chevy style. Not very common but that might be what the owner was trying to explain.
"Plumbnutz" you are right, they are the same as the Blazer.
Mkcustums is offline   Reply With Quote
Old 12-30-2007, 07:29 PM   #9
cartman
Look at the production date. it could be a "89" that was built in late 88 which had the "stacked" headlamps you are talking about. rember any GM vehicle built after the 6th month of the year is considered the next model year. so a truck built in 7/88 would be considered a 89
cartman is offline   Reply With Quote
