12-11-2007, 03:56 PM | #1 |
gas tank leak -
I just filled my tank and I started to smell gas, and pulled the seat back to find it leaking - I think it was from the inside ring, not the outside, but I was wondering what the fix was -? Not fill it so far? Is there a seal?
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD Click here to support the board Philippians 4: 6-7 |
12-11-2007, 04:29 PM | #2 |
Re: gas tank leak -
There is a rubber "o" ring under the sending unit. The outer lock ring is on top of the sending unit. Would be my guess the "o"ring is shot and needs to be replaced,,,,,yesterday. I would start there and see if that fixes it. Most of the board vendors should have the "o" ring and probably won't cost 10.00-12.00 plus shipping.
Until you get it replaced don't fill it up so far. OR you could swap to a blazer tank mounted in the rear under the bed. Just my .02
70 chevy lwb c10 454/th400 and a 9" rearend suicide doors, marker light fuel fill, 4" cowl , mini tub Last edited by sick69; 12-11-2007 at 04:33 PM. |
12-11-2007, 05:06 PM | #3 |
Re: gas tank leak -
just remember: DONT WELD IT!!!
Travis
travis_moffatt@hotmail.com 1969 Chevrolet C-10 LWB, 350c.i., TH350, In Pieces. 1991 GMC Sonoma, IROCS s10 grill 1963 Ford Galaxie 351/C4 |
12-11-2007, 05:59 PM | #4 |
Re: gas tank leak -
Thanks, guys, that's where I'll start -
12-11-2007, 09:09 PM | #5 |
Old member
Re: gas tank leak -
I saw a gas kit the other day in Advance for the twist locks with a assortment of o-rings.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
