Old 12-12-2007, 10:44 PM   #1
ksjh1316
ksjh1316's Avatar
Ram Assist vs PS
Heres the dilima I am building a 67 Chevy SWB from the ground up and want to stay halfway with the same year parts but am going to use my front end off my 71 GMC for the disc brakes and safty. The current set up on the Chevy is man steering which will be easier to install on the frame the ram assist or ps and which would you go with. Thanks for all the help from the experts I know are out there.
ksjh1316 is offline   Reply With Quote
Old 12-12-2007, 10:55 PM   #2
Andy4639
Old member
Andy4639's Avatar
Re: Ram Assist vs PS
If your adding the 71 front end I would go with the power steering off of it. The power assit isn't that great from what I remember.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 12-13-2007, 11:48 AM   #3
boundstaffpress
Jamie Hyneman is my twin
boundstaffpress's Avatar
Power ram is scary!
My 67 nova had one, and talk about bump steer. If the valve is not adjusted just perfectly, you can chase it all over the highway. It worked great for in-town driving, but at 67-75 you'd better not be sleepy.
Justin
SOLD 1967 K10 Fleetside, 283, Front and Rear Posi SOLD
Color Wiring Diagrams Now in High Resolution
V8 and Cab and Cab and Chassis
boundstaffpress is offline   Reply With Quote
Old 12-13-2007, 03:04 PM   #4
Bob B.
'62-'67 Nova front ends were scary period! Yes, the control valve has to be adjusted properly, but if it is too touchy, it probably needs to be rebuilt or replaced. The biggest problems with ram-type P/S is that they are a bit prone to leaking and since it uses the same steering box as manual steering, the ratio is slow for power steering. Also, the wheel doesn't return to center by itself all that well. You can buy new hydraulic cylinders and valves if you go with the ram type.
1967 GMC CM-2500 Camper Cruiser, 351E V-6, NP 435 4 speed, Dana 60, and factory A/C. 2012 GMC K-3500 WT regular cab, 6.0L Vortec, 6L90.
Bob B. is offline   Reply With Quote
Old 12-13-2007, 04:21 PM   #5
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Besides all the extra linkages, they usually leak over time. They're old-school, for sure.
Member Nr. 2770
Old 12-13-2007, 06:31 PM   #6
DirtyLarry
Windy Corner of a Dirty Street
DirtyLarry's Avatar
Can that ram assist BS and use a power steering gear box. My 68 GMC originally had ram assist, which I got tired of fixing the leaks and herding it around on the highway. Finally hiked it and the manual steering gear in the trash and used a power steering gearbox instead. After I did that I wondered why I didn’t do that years ago.
DirtyLarry is offline   Reply With Quote
Old 12-13-2007, 08:39 PM   #7
wibilly
wibilly's Avatar
i'm guessing the ram asist can't be all that bad or it wouldn't hav been used in corvetts for so long
common sense isn't so common anymore
wibilly is offline   Reply With Quote
