Old 12-14-2007, 01:09 PM   #1
mtburg71
mtburg71's Avatar
Question about tranny's
Ok, newb question. Looking to put an automatic tranny in my 64 GMC which has a 3spd manual on the floor. What stock trannys are out there that could handle atleast 400hp, and will it bolt to my current 327? Will upgrade motor in the future that will potential, "cross fingers" make around 400hp. Just looking for simple answers as I know there are many variables out there. Thanks in advance.
Mike
1964 GMC SWBFS
2005 Dodge Magnum RT
mtburg71 is offline   Reply With Quote
Old 12-14-2007, 01:45 PM   #2
fuelpump
fuelpump's Avatar
Re: Question about tranny's
Mike
I would think a 700R4. It's used in a lot of street rods.
fuelpump is offline   Reply With Quote
Old 12-14-2007, 02:14 PM   #3
1966gmc
Why does it taste purple?
1966gmc's Avatar
TH350
TH400
2 speed Powerglide
1966gmc is offline   Reply With Quote
Old 12-14-2007, 02:30 PM   #4
drbyrdman
drbyrdman's Avatar
I have a 700r4 behind my 327.
drbyrdman is offline   Reply With Quote
Old 12-14-2007, 02:58 PM   #5
NF65Fleetside
NF65Fleetside's Avatar
Originally Posted by 1966gmc View Post
TH350
TH400
2 speed Powerglide
nuff said
NF65Fleetside is offline   Reply With Quote
Old 12-14-2007, 03:25 PM   #6
04Xrider
Registered thread killer
04Xrider's Avatar
I like the 700R4. It has a pretty aggressive 1st gear, so if you are hauling a load or pulling a trailer, it can easily get you rolling, and the overdrive is easy on the gas $$$. Just my two.
!966 stepside, 350 SB, ZZ-4 roller, Crane roller rockers, 0.030 flat tops, airgap intake, 750 Holley, stainless steel headers, edelbrock SDT mufflers, Mark 8 elec fan, 700R-4, column shift
04Xrider is offline   Reply With Quote
Old 12-14-2007, 03:53 PM   #7
mtburg71
mtburg71's Avatar
What type of vehicles have those installed stock, maybe I can pick one up at the junkyard. What would be the going price for something like that? Thanks for the info guys.
1964 GMC SWBFS
Old 12-19-2007, 05:52 PM   #8
Tomsriv
Tomsriv's Avatar
Mine has a 200-4R. The gear ratios are closer so you don't have as big a drop between 1st and 2nd. Also the overdrive is a slightly better ratio. I run mine without a lock-up TC so setting it up is simple. As for 400hp, it can be built to hold it with a few aftermarket parts. If you aren't running slicks you will probably not hook up good enough to break it. I've towed a yard of concrete with my truck and that is pretty hard on the trans as well.
Tomsriv is offline   Reply With Quote
