Old 12-17-2007, 03:42 PM   #1
dan42
dan42's Avatar
rubber fuel line in the cab -
Does anyone know it's O.K. to run rubber fuel line from the sending unit in the tank to the floor, and then switching back to metal fuel line on the frame? I can understand why not to run it around the motor, but in the cab, I can't see any problems. I was wondering if anyone has done this.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD
Click here to support the board
Philippians 4: 6-7
dan42 is offline   Reply With Quote
Old 12-17-2007, 04:11 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: rubber fuel line in the cab -
it's not the prefered method, but at least you'll have no doubt there's a problem once it rots away.
Old 12-17-2007, 04:25 PM   #3
cdowns
cdowns's Avatar
hot cross buns
Old 12-17-2007, 04:31 PM   #4
dan42
dan42's Avatar
Dang you guys, always throwing a stick in the works. I guess I'll use my little 7 dollar tube bender from Harbor Frieght to make it work.
Philippians 4: 6-7
Old 12-17-2007, 05:02 PM   #5
1971ChevyTruck
1971ChevyTruck's Avatar
I ran rubber from the fuel sender down to metal that ran through the floor...had a little bit of rubber from the cab to the frame to allow it to flex a little...never had any problems...
1971ChevyTruck is offline   Reply With Quote
Old 12-17-2007, 05:56 PM   #6
corn
Make sure you use a grommet if its going through any sheet metal. Ive never had a problem but Im a rule breaker...
corn is offline   Reply With Quote
