12-19-2007, 07:17 PM | #151 |
A guy with a truck
Re: How to: Ruin a perfectly good Blazer...
I've seen my share of bad bush too...
Got her ripped apart in preparation for the Dropmember. Nearly everything is off of the firewall and framerails. I've got some cleaning/painting to do after I weld up all the PO hacks. Someone got a little happy with the flame saw... No real progress shots- I was on a roll...
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
12-19-2007, 10:00 PM | #152 |
Chris,
Are your trailing arms touching the frame in the back? or is there a little more room to go down if your notch was a little taller? I am going to try and attack my blazer frame over the holidays. I'm out on the road working and can't go look at my frame right now, but still trying to get it all straight in my head. BTW, I'm jealous of the dropmember.
Steven "If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers R.I.P. Oscar R.I.P. Ratchet 1967 Pontiac GTO - Dad was the Original Owner 1970 Chevy 2wd SWB "Oscar's Truck" 1970 Chevy 2wd Blazer "Ratchet's Blazer" 2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar" 2017 Chevy Suburban "BDB" 2020 Chevy Blazer Premier "Foxy" Member of Louisiana Classic Truck Club (LCTC) Shop Build Last edited by smbrouss70; 12-19-2007 at 10:01 PM. |
12-20-2007, 03:02 AM | #153 |
A guy with a truck
They are very close. I'd say within 3/8". A 2wd frame may be slightly different.
12-20-2007, 04:15 AM | #154 |
12-20-2007, 12:29 PM | #155 |
Thanks! My blazer is a 2wd (body & vin), but I couldn't find a 2wd frame for it so I picked up a 4x4 to hack up. That'll make the purists happy!
Steven "If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers R.I.P. Oscar R.I.P. Ratchet 1967 Pontiac GTO - Dad was the Original Owner 1970 Chevy 2wd SWB "Oscar's Truck" 1970 Chevy 2wd Blazer "Ratchet's Blazer" 2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar" 2017 Chevy Suburban "BDB" 2020 Chevy Blazer Premier "Foxy" Member of Louisiana Classic Truck Club (LCTC) Shop Build |
12-20-2007, 05:42 PM | #156 | |
Check 'em out. http://67-72chevytrucks.com/vboard/s...d.php?t=198386
Jim '71 Blazer-Porterbuilt Dropmember C4/LS1/6L80E '57 VW beetle - Oct. 2006 Hot VW's pg. 87 - 350hp intercooled, turbocharged, EFI 2.3liter and 5spd in the works '87 BMW 325i - daily driver |
12-21-2007, 06:06 PM | #157 |
A guy with a truck
Welded up the mess made by the PO on the front framerails tonite. You can see in my previous post where there were huge holes in the sides and a portion just behind the steering box on the driver's side that was missing altogether. They are now fixed and ready for cleanup/paint.
Also got the last of my parts from Nate today for the Dropmember install. He sent me the new style shock mounts and a plate made for the LCAs so I can use them in lieu of ART arms. The bag mount is genius in its simplicity- it aligns using the sway bar mount holes, then drill three more, bolt it down, and- voila! lower bag mount.
12-21-2007, 06:11 PM | #158 |
its just $$$$$
if you dont mind me asking, how much did those shock mounts cost? I need to get some
12-21-2007, 06:14 PM | #159 | |
You should've had a set in your box... looks like I need to send you a pair your way.
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
12-21-2007, 06:17 PM | #160 |
Nate,
With all your new boxes and everytihng in it's place, I can't believe you would forget something like that.
12-22-2007, 04:39 AM | #161 |
Texas Big Wig
Not to hijack your thread, but...
I can can see how the lower bag plate would give you more lift & maybe make installation a bit easier, but will it let you go as low at dump ??? Cuz honestly I don't see a need for more lift in a ride that is supposed to ride low, cuz my setup gets it back up plenty high End of thread jack lol |
12-22-2007, 07:36 AM | #162 | |
On the fast track to nowhere..
-Mike Owen- Norwood, Houston, Cecilia, Jackson, Monroe and counting |
12-22-2007, 07:48 AM | #163 |
Texas Big Wig
I figured he knew what he was doing, but it just didn't make sense to me
12-22-2007, 08:38 AM | #164 | |
This bag plate is the way it is for a few reasons... the new centerline for the air spring is located outboard 1.25" from stock. This makes it necessary to heavily mod the stock lower arm to fit a bag in the spring pocket. In order to achieve a cost effective way to maintain the stock lower arm I made the plate like you see it. An ART Strong arm will get you more drop than the 73-87 stock lower and PB bag plate... but only 1". In the land of the low slung rides 1" can mean a lot, but in Gringo's case it doesn't. His frame is a 4WD and he already has to use stock spindles to keep it from being burried. Depending on overall tire diameter, spindle height, and bag selection, it is possible to lay frame with a factory 73-87 lower arm and PB plate. Of course that's when it's combined with a Dropmember.
12-22-2007, 01:59 PM | #165 |
Texas Big Wig
Man, the more I learn bout these drop members the more I want one ! |
12-22-2007, 03:14 PM | #166 |
A guy with a truck
Mmmm... Not much I like better than freshly powdercoated truck parts in the living room.
The Dropmember looks awesome with some color on it. My powdercoater liked it so much, he is talking about getting one for his '68 SWB that he is finishing up a restore on. Nate- do you offer discounts for referrals? Only work I got done was to install the motor mount bushings; busy wrapping presents...
12-22-2007, 04:16 PM | #167 |
Gringo, you rock. Oh yeah..................Nathan, you rock too.
12-22-2007, 04:31 PM | #168 |
its just $$$$$
12-22-2007, 05:49 PM | #169 |
The parts look great! What finish is that? I can't tell if it's a semi-gloss or....????
12-22-2007, 06:24 PM | #170 |
A guy with a truck
Thanks, I can only take partial credit It's a 'satin' finish. Looks more like a semi-gloss in pics. I wanted a finish I could easily clean since it will be in the engine bay. It also matches my control/trailing arms, crossmembers, etc...
12-22-2007, 07:49 PM | #171 |
Texas Big Wig
Thats one thing I love about powder coat, it's really easy to keep clean
12-23-2007, 04:00 AM | #172 |
Tot Roddin'
Just be sure to have that drop member wrapped in time to get it under my tree......
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
12-23-2007, 04:26 AM | #173 |
I'm getting the one for my 68 done in satin-black too. Should look nice w/the stainless hardware .
12-23-2007, 06:14 AM | #174 |
You'll have to change that quote in your sig then or be guilty of 'hipocrisy' . ......
12-23-2007, 08:20 AM | #175 |
Texas Big Wig
I dunno, they may be very unique but he built more than one so it's not so custom anymore
If every one had something different about it, then it would be custom |
