12-20-2007, 09:11 AM | #1 |
Pictures needed....
I need some pictures of the rear brake line routing and connections for 3/4 T truck or suburban. Thanks in advance.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
12-20-2007, 11:37 AM | #2 |
its all about the +6 inches
Re: Pictures needed....
you talking along the frame, or off the master... or all of it? Also, what year you interested in here?
12-20-2007, 02:47 PM | #3 |
Where the hard line connects to the rubber line that goes to the rear axle.
12-20-2007, 03:41 PM | #4 |
What model frame is it? The 72's usually mount in a different location.
12-20-2007, 03:42 PM | #5 | |
R
12-20-2007, 04:47 PM | #6 |
Should be pretty close to a 1/2 ton setup other than the different style rear ends. Here is a Dana and an Eaton.
12-20-2007, 04:48 PM | #7 |
Few more.
12-20-2007, 05:01 PM | #8 |
Cool. 1/2 T hard line ends on the frame just prior to the rear axle.
12-20-2007, 05:16 PM | #9 |
Maybe on a 71,but these were both 72's. That's the main difference. The 72 line ran over and came out right above the chunk.
12-31-2007, 01:46 PM | #10 |
Would you happen to have the bracket that they union block and the rear rubber hose bolt to? Thanks,
12-31-2007, 02:34 PM | #11 |
Are you talking about the one in the pics?
12-31-2007, 02:55 PM | #12 |
12-31-2007, 03:11 PM | #13 |
That's on an Eaton rear. What are you using? There may be a difference in the line sizes. I'm sure I have one around here somewhere.
12-31-2007, 03:24 PM | #14 |
I have a 12 bolt. All I need is the bracket that bolts to the rearend, not the rubber hose.
12-31-2007, 03:34 PM | #15 |
I'll try to get my hands on one Monday.
01-03-2008, 05:07 PM | #16 |
Bump.
