12-17-2007, 07:43 PM | #526 |
Never Done?
Re: Joined the Short Wheelbase Club *69 Tahoe Project*
Frizzle, I like how the rear discs are coming together. I just bought my calipers and pads off eBay and I'm watching some rebuild kits. Those rotors oughta appear tiny behind those 22s!
12-17-2007, 09:11 PM | #527 |
12-18-2007, 08:16 AM | #528 |
Got some more goodies on the way... Time to break out the 4" holesaw
...and |
12-18-2007, 08:31 AM | #529 |
Friz,
Who's headers are those? They look very nice. Are you running a LS series engine?
Jim '71 Blazer-Porterbuilt Dropmember C4/LS1/6L80E '57 VW beetle - Oct. 2006 Hot VW's pg. 87 - 350hp intercooled, turbocharged, EFI 2.3liter and 5spd in the works '87 BMW 325i - daily driver |
12-18-2007, 08:32 AM | #530 |
Nice! Who makes the kit and is it SS or alum coated?
Kevin LFD inc. |
12-18-2007, 08:58 AM | #531 | ||
12-18-2007, 11:23 AM | #532 |
A guy with a truck
Those Flowmaster pipe kits are nice. They will, however, leave you wanting an extra set of 45* bends since they are designed for longtubes...
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
12-18-2007, 11:37 AM | #533 |
All the rear brake parts are ready to go. I have have all new bearings front and rear ready to go in. Pads will be here Monday and the ebrake cables sometime this week.
But there's always some kind of set-back... One of my calipers was sent with the wrong bracket. First two show the incorrect bracket (Corvette) and the third is the Camaro bracket: |
12-18-2007, 11:39 AM | #534 |
12-19-2007, 05:07 PM | #535 | |
This board creates such a conundrum. I find one thread that helps me get stuff done faster and more efficient and then I find another that makes me want to take 3 steps backwards........ must have more willpower must have more willpower must have more willpower must have more willpower must have more willpower must have more willpower must have more willpower
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 12-19-2007 at 05:08 PM. |
12-19-2007, 05:17 PM | #536 |
OK, I've got some more questions on your brakes.
Am I reading correctly that the rear brakes are from a camaro? What year range and what is required to make them work - besides the brackets? Anything? Do they need to be modified to fit a truck 12bolt? Are you running the 5x4.75 bolt pattern or are you staying with the 5x5? I'm going to be running C4 stuff on the front of mine and am trying to figure out what to use to get the same pattern on the rear. Where do "Glock's" brackets come from? I'm familiar with the firearm but not brake brackets. Sorry for all the questions but this sounds like a good way to go and I have easy access to camaro parts.
12-19-2007, 05:24 PM | #537 |
Glock is the board member that makes the brackets.
Steven "If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers R.I.P. Oscar R.I.P. Ratchet 1967 Pontiac GTO - Dad was the Original Owner 1970 Chevy 2wd SWB "Oscar's Truck" 1970 Chevy 2wd Blazer "Ratchet's Blazer" 2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar" 2017 Chevy Suburban "BDB" 2020 Chevy Blazer Premier "Foxy" Member of Louisiana Classic Truck Club (LCTC) Shop Build |
12-19-2007, 05:44 PM | #538 |
I was wondering if that's who that was.
I'm guessing there is a thread on the brakes somewhere? I'll look around for it. Thanks
12-19-2007, 05:56 PM | #539 |
OK, I found the thread but no more brackets.....
12-19-2007, 06:37 PM | #540 |
I think he's planning to make another run of them. He also makes brackets to run caprice/impala calipers. I went with the camaro's to retain a functional e-brake.
12-19-2007, 06:40 PM | #541 | |
12-19-2007, 06:56 PM | #542 |
A guy with a truck
Me2...
12-19-2007, 07:31 PM | #543 | |
Now you guys give this board way too much credit! I have been cutting vehicals for years! This board just gives us someone to share it with First victam 63 VW bug age 14 and it has gotten worse with every killing since. Every now and then you save one and it makes it all worth it! Because then you can cut it again!!! Kevin LFD Inc. |
12-19-2007, 08:03 PM | #544 |
I'M TRUCK CRAZY!
This is going to be a very nice ride!
This board is great |
12-20-2007, 03:26 AM | #545 | |
I pm'd him so I'm on the new waiting list. Thanks
12-20-2007, 06:43 PM | #546 |
Hey Kevin I started out with a 67 Bug. Rolled it before I even had my license...
I was asked about a parts list for my rear discs. Here it is:
12-20-2007, 07:41 PM | #547 |
Mocked up the rear brakes with the calipers swapped side/side and facing forward instead of toward the rear. I think I'll run them this way. Just looks better IMO and may have minuscule performance advantage over hanging them off the rear of the axle. after the pics I pulled it apart and POR-15'd the axle tubes:
See, that's the way they should go. Front calipers toward rear and rear calipers toward front: Last edited by Frizzle Fry; 12-20-2007 at 07:48 PM. |
12-21-2007, 02:55 AM | #548 |
Makes sense to me. I'll prolly do the same.
12-21-2007, 04:06 AM | #549 |
Never Done?
Looks good! I also agree about running the calipers towards the front.
I can't wait for my calipers to show up. |
12-21-2007, 10:25 AM | #550 |
FYI, some calipers are built to go a certain way to maintain proper pad wear. I know that front calipers on my 914 have the pistons notched so that the pads sit slightly angled.
-Britain |
