12-21-2007, 12:48 PM | #551 |
A guy with a truck
Re: Joined the Short Wheelbase Club *69 Tahoe Project*
Did you get them from the guy that uses this stock photo?
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
12-21-2007, 12:58 PM | #552 |
I got them from this guy for $190/pr via best offer (he wouldn't come down much). The quality is good though not perfect show quality; mine's a driver. He did send the wrong bracket on one of the calipers but he says he has the right one on it's way. Doesn't look like he has listed another pair of the 93-97's yet but it wouldn't hurt to send him an inquiry.
12-21-2007, 01:37 PM | #553 |
I got my camaro calipers and brackets from the salvage yards. I'll rebuild them sometime.
I always have thought the positioning of the brake caliper really doesn't matter, except for weight distribution, and on our trucks it would be best to have them on the back. That's where I put mine. |
12-21-2007, 07:39 PM | #554 |
I could see where an argument could be made to put them in the rear for traction. I'm thinking along the lines of unsprung weight. Moving the weight toward the trailing arm pivots would be an improvement in that regard.
12-22-2007, 05:23 AM | #555 | |
It's the same weight, different moment. In all reality though, it's so little weight compared to other things, it really doesn't matter. |
12-22-2007, 09:11 AM | #556 |
12-22-2007, 09:17 AM | #557 |
Next project: 1970 K10
Either way, they look purdy!
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE |
12-22-2007, 09:24 AM | #558 |
More progress on the brakes. The hubs have about a 1/16" ridge that prevents the rotors from seating all the way down on the flange. I was able to remove it with careful and even application of a die grinder:
12-22-2007, 09:37 AM | #559 |
Looking sweet! Great work like always!
Josh
(Project truck) 1970 C10 under complete transformation My current build thread http://67-72chevytrucks.com/vboard/s...d.php?t=212871 Other project: C5 corvette swap into 70 c10 http://67-72chevytrucks.com/vboard/s...=1#post2413517 On Hold |
12-22-2007, 09:39 AM | #560 |
12-22-2007, 09:47 AM | #561 |
Then the fronts got a few coats of the high temp silver, and the axles got some black:
12-22-2007, 10:33 AM | #562 |
Never Done?
Looks great! You're making me jealous! I'm interested in seeing what it takes to hook up the emergency brake cables. My calipers just showed up yesterday complete from pads to cables, but it's all pretty ugly used stuff.
12-22-2007, 03:00 PM | #563 |
A guy with a truck
I did the same thing, just spun them on the spindle. Lookin' good!
12-22-2007, 04:11 PM | #564 |
I wonder is that same modification is needed on the C4 spindle?
I guess I'll know soon enough.
Jim '71 Blazer-Porterbuilt Dropmember C4/LS1/6L80E '57 VW beetle - Oct. 2006 Hot VW's pg. 87 - 350hp intercooled, turbocharged, EFI 2.3liter and 5spd in the works '87 BMW 325i - daily driver |
12-22-2007, 05:35 PM | #565 |
12-23-2007, 12:52 PM | #566 |
Well, I ran into a minor snag on the rear brake conversion: I got the new bearings in and went to put the seals on... wrong size Since this is my driver I have to wait for my GF to get home so a can make a NAPA run...
But I roll with the punches; Got one of the front rotors installed with all new bearings and fresh red stuff. Now back out to do the other side! |
12-23-2007, 01:31 PM | #567 |
Active Member
Truck is coming together very nicely I am addicted to this thread. That seems to be the norm on the rotors for wheels that have caps I had to do the same.
12-23-2007, 02:29 PM | #568 |
A guy with a truck
Geez, man. New hub caps are like $2 a pair at NAPA... jk- lookin' good. Just ordered my rotors today. You should make a commission off of all the sales this thread has led to. Hell, my purchases alone could fund your next mod
12-23-2007, 02:34 PM | #569 | |
Frizzle, Sorry, I should have stated that I'm running the same wheels but since it's a defferent spindle I may not have the same problem. I'll know soon enough. I'm gonna try to actually start something on my truck tomorrow. : I have to check my kid's schedules and make sure there aren't any basketball games or birthday parties or .................. you get the picture.
Jim '71 Blazer-Porterbuilt Dropmember C4/LS1/6L80E '57 VW beetle - Oct. 2006 Hot VW's pg. 87 - 350hp intercooled, turbocharged, EFI 2.3liter and 5spd in the works '87 BMW 325i - daily driver Last edited by babyblueoval; 12-23-2007 at 02:46 PM. |
12-23-2007, 04:36 PM | #570 | ||
You know I thought about replacing them and then I thought it was probably one of those parts the wasn't commonly stocked by the parts stores... Didn't even think to ask. Now I'm gonna have too... That's $2 in sales for you oh wait, plus the Coys Quote:
12-23-2007, 04:40 PM | #571 |
Got the other side done. Also figured out the rear end outer seals after two more trips to NAPA... Not sure why the part numbers weren't correlating. Here's the passenger side. Rear brakes will go together tomorrow
Don't mind my fender pocket; it's getting a whole new clip |
12-23-2007, 04:46 PM | #572 | |
Thanks for showing what you did.
12-23-2007, 04:53 PM | #573 |
A guy with a truck
Check the HELP aisle...
12-24-2007, 10:03 AM | #574 | |
Roger that |
12-24-2007, 02:56 PM | #575 | |
