Old 12-21-2007, 12:58 PM   #1
Blue71LWB
Blue71LWB's Avatar
Lean/rich indicators ?
Are any of you guys running a lean/rich indicator sensor ?
MSD sells a kit, anybody used that one?
Anybody got a set-up they suggest
Working on my first 1,000 post.
I'm sure I'll get there before this project is over .
Blue71LWB is offline   Reply With Quote
Old 12-21-2007, 01:04 PM   #2
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Re: Lean/rich indicators ?
Short of having a meter (which I do) to measure the air/fuel ratio at the tailpipe, I have had more luck with my nose. If the mixture is rich, it'll bring tears to your eyes and burn your nose. On the lean side, it may be hard to crank when it's hot, because a lean engine runs hotter and the heat soak will affect the starter.
Member Nr. 2770
Old 12-21-2007, 01:09 PM   #3
fastom
That's right, it's Copper!!
fastom's Avatar
I have the NGK AFX meter, it works great. I have used others but the wideband sensor is much better.
http://www.ngk.com/afx/
fastom is offline   Reply With Quote
Old 12-21-2007, 01:25 PM   #4
WorkinLonghorn
WorkinLonghorn's Avatar
Looks like a good thing to have. I notice you can get them on ebay for a lot less.
http://cgi.ebay.com/ebaymotors/NGK-N...ayphotohosting
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme.
WorkinLonghorn is offline   Reply With Quote
Old 12-21-2007, 01:57 PM   #5
cdowns
cdowns's Avatar
your spark plugs will tell you everything you need to know
Old 12-21-2007, 02:11 PM   #6
68caliRat
Need a bigger hammer..
Yup try this link
1968 GMC 3/4 LWB fleetside Custom Camper
2018 Silverado High Country 2500HD Duramax 4X4
68caliRat is offline   Reply With Quote
Old 12-21-2007, 03:02 PM   #7
68K20 x Drill
Innovate makes by far the best display I've seen
http://www.innovatemotorsports.com/products.php
this controller may be decent, and the price is great
http://www.14point7.com/JAW/JAW.htm
Spark plugs may tell you everything, but a wideband with datalogging can tell you everything in one pull without opening the hood.
68 Chevrolet k20 Longbed 350 SM465/205, Dana 44, 14bolt, Power steering, Power Disk Brakes, 35" BFGs.
84 Chevrolet Suburban K20 6.2 Banks turbo TH400/NP208 Now with G80
68 GMC C20 Parts? Truck
And a few cars
68K20 x Drill is offline   Reply With Quote
Old 12-21-2007, 06:43 PM   #8
Jim_PA
Originally Posted by 68caliRat View Post
Yup try this link
<bubbaspeak>
I don't know... one of those wide-band O2 magillicutty's would be pretty nice on the backside.
</bubbaspeak>
Jim_PA is offline   Reply With Quote
Old 12-21-2007, 08:15 PM   #9
60ratrod
yes, i do
60ratrod's Avatar
but that link is a good one. i book marked it for future reference.
ERROR 404....... SNAPPY COMEBACK NOT FOUND
_______________________________________________________________________________________________
-60 Chevy C10, dead 350/good th350 combo, sitting on a 76 c10 blazer frame, built from 11 different vehicles "the abomination"
-07 gmt900 silverado 1500 lt xcab z71, granite blue
-81 suzuki gs650g "shelah"- current project
-81 kz1000m1 csr "sarge" -next project (just beautification)
-07 kawasaki vulcan classic vn900
60ratrod is offline   Reply With Quote
Old 12-22-2007, 02:05 AM   #10
mnunn454
mnunn454's Avatar
I bought a a/f meter at AutoZone and installed unheated O2 sensors in the header collectors. Total cost was less than $100 including welding two bungs into the collectors. While narrow band sensors are tuned specifically for 14.7 a/f ratio and aren't as informative as the wide band plus a data-logger, you can still do a lot with them if you'll "mentally average" what the gauge is telling you. I've adjusted my Holley 750DP's jetting so that it's averaging 14.7 a/f on the highway, then turning mostly green (richer than 14.7) when I'm really getting on it.
If you have the cash, the better solution though is the wide-band + data logger for sure.
69 C-10 SWB Fleetside 454/TH400 (For Sale)
http://67-72chevytrucks.com/vboard/c...ct=1299&cat=12
70 El Camino 454 TH700
29 Model A 4-DR Sedan Deluxe
mnunn454 is offline   Reply With Quote
Old 12-22-2007, 02:18 AM   #11
In my Sierra I have a vacuum gauge mounted on the dash.It helps me gauge my fuel economy by letting me "gauge" my fuel to air mix.It`s amazing how a slight lift of the right foot can maintain the same speed,yet increase the economy.The gauge is color-coded to indicate Power,Driving,Idle,and Economy.In that order.I can roll along and consume less than idle.They used to put vacuum gauges in cars back in the early 60s.I don`t know why the government hasn`t mandated them if they are truly concerned with conserving fuel.
