I blew up my transmission im my 1987 silverado and i swapped it out
with a different transmission and torque converter. and it moves fine and everything but theres a LOUD knocking coming from the flywheel/ bellhousing/area i dont know what the hell it is any suggestions???? and it has fluid in it and the torque converter bolts are really tight and i didnt remove the flywheel so its not that and i also inspected the flywheel for cracks any one know whats going on??? |
STILL PLAYS WITH TRUX
Welcome to the board!
Sorry about the death of your tranny i am assuming your new trans is also a 700r4 as well. Is this a rebuilt unit or a used unit? same ? for the converter. It sound's like it could be the front plantary gears or the pump but it's hard to say for sure. |
Robert Olson Transport
![]() Join Date: Oct 2002
Re: 87 chevy tranny help
ive seen perfectly good flywheels crack when the tranny is replaced sounds to me like the flywheel went youre going to have to drop the trans anyway or at least pull it forward prior to removal so check the flywheel its possible one of the torque converter to flywheel bolts broke or something too if they were put on too tight but ive had several over the years do this it sounds almost like a real bad motor bearing
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! |
They are both used but in good shape yes 700r4 any other suggestions working on droping the tranny as we speak...How do i know if it is a bad pump? of course I have to take it out but how do I tell if it is bad thanks for all the help.
One shot, one kill.
Chevy. Seeing as your going to pull the old slush box, check this beforehand. Remove the torque converter to flexplate bolts. Try to pry the torque converter towards the rear of the truck. You should be EASLY able to attain 3/8 to 1/2 inch of clearence. If you can't, then the hub on the torque converter didn't properly engage the pump drive gear in the trans when you swapped it out. In this case the front pump is going to be trash. If you can attain the clearence, pull the trans back as far as you can and with a flashlight look up at the end of the crankshaft where the flexplate bolts on. If you see alot of very light powdery rust colored deposits, the flexplate is cracked. If you grab ahold of the flexplate and try to bend it front to back it might make a creaking noise, MIGHT is the key word here. If you rotate the eng 360 degrees a little at a time you might be able to see a shiney spot where the crack is. I have seen flexplates cracked all the way around the crankshaft hub and had it litterly fall out when the converter bolts were removed! Hope this helps, jim
Jim is right, and surprisingly, you can still drive with it cracked all the way around if you don't mind the racket.
68 Chevrolet k20 Longbed 350 SM465/205, Dana 44, 14bolt, Power steering, Power Disk Brakes, 35" BFGs. 84 Chevrolet Suburban K20 6.2 Banks turbo TH400/NP208 Now with G80 68 GMC C20 Parts? Truck And a few cars ![]() |
i thought about moving the tranny back
myself but i dont have very much free time i think i am going to do that this weekend though i just wanted to explore all my options before i went and redrooped the tranny for spark knock or something it deffinetly sounds like i dropped a bolt in my torque converter or something..... is that a possibility and also too i forgot to fill the converter up with fluid before i installed it will that do it???? it had a little bit in it not much though.... thanks for all the help |
One shot, one kill.
Chevy. haveing the converter empty on install isn't a problem if you fill the trans to mark as soon as you start up. You might have left a converter bolt loose and it fell out. That would certainly make a racket. Bottom line is pull the trans back and look. jim
My truck is an alcoholic
Did you use the bolts that came out of the old converter, or just some that fit in the holes? Have had people replace transmissions, lose the converter bolts, then find they have a knocking noise. The bolts are short for the converters, if you use a 1" or longer bolt it will bottom out before it holds the flywheel. It makes a noise just like a rod knock when it happens.
If the thing moves, the pump is usually ok. No pump = no pressure = no movement because nothing will apply. Other than the bolts, a knocking noise is the flexplate cracked or loose. Chevies tend to break flexplates, must be cheaper metal than the BOP flexplates. Still havent broken a Pontiac plate and they have been behind 500-700hp drag engines with high stall converters. Have cracked 3 plates behind 305s with two barrel carbs. |
i moveed the converter fine it definetly was enagaged yes i used the same bolts for the converter its not tthat the only thing i see wrong with the flexplate is like a few teeth are worn on the edges like 4 teeth
okay i took the transmission out i and started it.... its still making the noise. i took the flywheel completly off no cracks or nothing like that... thrown motor bearing? Get a new flywheel and test it again with a new flywheel???
One shot, one kill.
Chevy: Flywheel is definately bad and will have to be replaced. Starter clutch (the gear part) or solinoid cause teeth to get "ripped off". Replace them both and try again.
I do, however, doubt they are the source of this noise. Lets do a little digging here. First, the noise wasen't there before the swap, so, obviously you did something. Oddly enough I want you to check the distributor, specificly the cap. When you drop the back of the engine to get the trans out the cap hits the firewall and will get cocked to the front just a bit and will stay cocked after your done. When you start the engine the rotor hits the cap and it makes I racket. If you find this to be true, replace the cap and rotor with GM ones. Aftermarket caps are thin in the coil screw area and the spark will jump to one of these screws and you'll wind up with a skip. If that isn't the problem next place to look is the front of the engine. Quick check is take off the drive belts and start it up for a minute. If the noise is gone, check all the rotating members for something bent, sticking or out of position. Check the fan blades and the fan shroud. I HAVE MADE THESE MISTAKES MYSELF. If you still have the noise, the last place to check is the oil pan. Did you use a floor jack under it when you swapped out the trans? Bottom of the pan HAS TO BE PERFECTLY FLAT!! The oil pump pickup screen is only about 1/2 to 3/4 of an inch away from the pan so if the pan is squashed up it could block off the pickup screen and starve the engine for oil and turn it into a good boat anchor. Let us know, jim
1984 K20 350M engine with 465,000 miles. Well, it's finally done!! Almost 2 years of work, but it was really worth the effort. Little stuff left to do is mount winch, wet sand & buff out and build belly pan\running boards. Body work takes lots and LOTS of beer!!!! God, Guts and Guns made America and God, Guts and Guns will preserve it! The worst thing you could do is get into my sights, but that don't matter, you'll never know it, cause you'll never hear the shot ![]() |
i took off the cap like you suggested there is a pretty good gash in it i dont know if thats the source of the problem yet or not but i will go to the auto parts store later on today and pick up a cap and rotor and see if it gos away i didnt do anything with the engine it just stayed in place i just put a jack stand and a piece of wood under it to support it just in case but i did not drop the engine at all...... if this cap and rotor idea does not work i will try the belts next thanks for the help james
You didn't happen to place a jack under the engine's oil pan did you? Sometimes people jack the engine up in this manner to line things up. Bad move! People that have done this sometimes tweak it just enough for the crankshaft to hit the pan in the shallow end. Take a look at it.
#15 |
No i didnt place a jack under it to line things up. the transmission is completly out right now so its something motor related obviously i put a new 350 flywheel on it. the cap and rotor are brand new now..... so it wasnt that. i looked in the fan shroud area nothing is knocking in there either.. also too its not the starter i also replaced that.i have yet to try taking the belts off ill go do that now
#16 | |
I was referencing your original post. You said you blew the tranny and replaced it. You didn't allude the noise was there before but, after tranny replacement. If the pan got tweaked in your original repair/replacement, it still would be tweaked even if you subsequently remove the tranny. sorry for not being helpful. |
#17 |
no no no all help is appreciated please if you have any other suggestions i appreciate them all because im still stumped im starting to think its the starter does any one know a good way to test to see if the flywheel is maybe hiting the starter a lil???
#18 |
witness marks on the starter, meaning there would be a spot where the starter has gouges or scrapes from the flex plate hitting it. Smack steel against aluminum and the aluminum will give every time..
![]() Im beginning to think its a bearing.. hate to say it, but it is possible.. |
#19 |
yeah me too
![]() Last edited by chevy_power1995; 01-02-2008 at 11:37 AM. |
