Old 12-23-2007, 11:33 AM   #1
Old Chevy Mech
Keepin it runnin!
Old Chevy Mech's Avatar
Speed Limitations
I was wondering what the fastest you all would go with your trucks in 4wd? My 70 Blazer with a Dana 20 I've always limited myself to 45 mph.
I have no clue what I should limit myself to with my K20 with a 4 speed & NP205 though. Any advice or experience is appreciated.
Thanks& Happy Holidays!
Frank
1970 K-5 4X4 Blazer
1970 K-20 4X4 Long Bed
"Liberty Means Responsibility, that is why most men dread it"
Old Chevy Mech is offline   Reply With Quote
Old 12-23-2007, 11:59 AM   #2
Blazer1970
Blazer1970's Avatar
Re: Speed Limitations
I have no problem driving 60 mph plus in 4WD on snowy roads. It will not hurt anything in your drivetrain - what you feel is a safe speed for the conditions is a personal decision.
Blazer1970 is offline   Reply With Quote
Old 12-23-2007, 05:23 PM   #3
70rs/ss
70rs/ss's Avatar
DEPENDS HOW SAFE YOUR RIG IS AND HOW GOOD YOUR STEERING, SUSP PARTS ARE. iF IT IS NICE AND TIGHT AND THE BRAKES WORK 70-80 IS ok (SORRY FOR THE CAPS!) It depends too on the axle ratio, 3:08 and 80 is OK, 4:11 and 55 may be the tops.
70rs/ss is offline   Reply With Quote
Old 12-24-2007, 04:38 AM   #4
Old Chevy Mech
Keepin it runnin!
Thanks Guys!
My Dad always limited the speed in our 4x4 70 Jimmy to 45 mph for whatever reason so that "number" stuck with me. I've not found anything in writing that says anything about speed limitations on the drive train one way or the other so thats why I'm asking.
Thanks!
Frank
1970 K-5 4X4 Blazer
Old 12-24-2007, 12:27 PM   #5
cobinder
Everything is work in progress
cobinder's Avatar
My thought is, the more miles you have on your drivetrain without replacing some of the parts that wear out (u-joints, hub needle bearings,etc) the more you need to consider how fast you want to go when locked in 4wd. If at 50mph the noise from your drivetrain exceeds the 3/4 sound level on your stereo, you might want to back her down a bit.
The faster you go the higher the chance a worn part will have a failure.
Good luck with your truck!
How much?! It's just an old truck part!!
49 International on a 80 GMC 3/4ton 4x4 chassis
48 International KB-5 2 ton dump bed
04 Honda CRF "500"
09 Honda CRF450 fuel injected rocket
03 Suzuki hayabusa carbonfiber wheeled monster.
02 Ford diesel stretch van (toy hauler)
01 38' Monaco diesel pusher motorhome
cobinder is offline   Reply With Quote
Old 12-29-2007, 05:53 AM   #6
Old Chevy Mech
Keepin it runnin!
The drive train is tight, I was just wondering if there was a GM recommendation on speed limit while 4wd was locked in. I believe some older international scouts had warnings not to exceed 45mph while in 4wd, but then I dont think those old scouts would do over 55 on a flat anyway. I dont understand why unless the transfer case cant handel it. I think most of them had dana 20 cases, they just had the rear output shaft coming out the lower end. My Blazer has the Dana 20, thats why I'm wondering...
Frank
1970 K-5 4X4 Blazer
Old 12-29-2007, 06:14 AM   #7
Yukon Jack
Yukon Jack's Avatar
Am I assuming correctly that you are talking about going those speeds on snow packed roads?
You wanted to stay out of 4wd when the roads are mostly clear as the Dana 20 and NP205 you list won't allow any differentiation between the two axles. You can bind up your driveline if there isn't any way for the axles to slip a little bit.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 12-29-2007, 11:10 AM   #8
Old Chevy Mech
Keepin it runnin!
Yes, I was thinking snow, dirt or gravel only. Just didnt say that! LOL
Frank
1970 K-5 4X4 Blazer
