Old 12-23-2007, 01:18 PM   #1
Sinister
Between Trucks...
Sinister's Avatar
Question LMC Heavy Duty Headlight Harness
Anybody using the LMC Heavy Duty Headlight Harness? I wanted relays for my headlights but didn't want to hack up the stock wiring. Supposedly it's plug and play...
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 12-23-2007, 01:58 PM   #2
webbes
Re: LMC Heavy Duty Headlight Harness
Works good in my truck so far but I just drove it last night 20 miles easy to install
1970 4X4 LONG BED 350 TPI 700R4
webbes is offline   Reply With Quote
Old 12-23-2007, 02:06 PM   #3
Sinister
Between Trucks...
Sinister's Avatar
Cool, thanks webbes. Just ordered one as an X-mas gift to myself...
Beat it to fit,
Old 12-23-2007, 02:11 PM   #4
Hoss72
Do they put out that much more light? I'm assuming you bought the Halogen Headlight. If they work good I will order some.
Hoss72 is offline   Reply With Quote
Old 12-23-2007, 02:30 PM   #5
Sinister
Between Trucks...
Sinister's Avatar
I just ordered the harness with the relays, didn't get the halogens. I'm more concerned about the voltage going through the light switch and under dash harness.
Beat it to fit,
Old 12-23-2007, 04:19 PM   #6
webbes
Just order the harness for now. Still trying to get all the bugs out of my truck. Install a tpi motor in it. Working out good so far
Old 12-23-2007, 05:37 PM   #7
Musclerodz
Harness is junk IMO, I bought a couple and they are cheaply made. Instructions are not even in English! AAW's relay kit is twice the price, but I feel it is twice the product, USA made and instructions in English.
Mike
Mike Redpath
Musclerodz is offline   Reply With Quote
Old 12-24-2007, 02:30 AM   #8
72freak
Rottenwood Garage Member
72freak's Avatar
Member "old yella" or "old yellow" has one
2004 Chevrolet Suburban C1500
2001 Chevrolet 2500HD Crew 6.0
1999 Harley Davidson Electra Glide
1972 Chevrolet C-20 Custom Camper "Dump Truck"
1972 Chevrolet C-20 Suburban "Big Green"
1969 Chevrolet C-50 Wedge Hauler "Leonidis"
1966 C-10 2x4 short fleet 327 4 speed "Race Truck"
1952 Plymouth Cranbrook "Rican" (my grandfathers)
1931 Ford Model A Coupe "Black Beauty"
1930 Ford Model A truck "Club Cab" 4x4
Rottenwood Garage and Speed Shop.....where everything must be racy!
It's not just a hobby..It's a LIFESTYLE!!!
Thanks for nothing Barrett-Jackson
You cant fix stupid or teach accountability!
Time wasters, looky Lous and tire kickers are everywhere!
72freak is offline   Reply With Quote
Old 12-24-2007, 04:37 AM   #9
LockDoc
The Older Generation
LockDoc's Avatar
webbes, do you have a build thread? I am in the process of installing a TPI/700r4 setup in my '70...
LockDoc
Leon
Old 12-24-2007, 04:54 AM   #10
Andy4639
Old member
Andy4639's Avatar
Head light relays:
This has been a hot topic now for awhile. It seems to me to be a rather simple solution.
Buy two relays at NAPA or any other part store. Mount them close to the driver's side head light. Clip the two head light wires (low) & (high) about 6" away from the light. One end from the dash goes to the incoming switch terminal. The other end connects to the outgoing. Run a hot wire from battery and jump it off both relays. Connect a ground to both relays and your done. Typical wiring for a relay. I may even do this this weekend myself.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 12-24-2007, 05:01 AM   #11
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
I would not buy anything from L.M.C.
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 12-24-2007, 05:29 AM   #12
Ricks1971
Ricks1971's Avatar
I have been looking at these guys wiring harness.
http://www.americanautowire.com/FactoryFit.html
Rick
Ricks1971 is offline   Reply With Quote
Old 12-24-2007, 05:59 AM   #13
BLACK AND BLUE 67-72
Firefighter
BLACK AND BLUE 67-72's Avatar
Question Re: LMC Heavy Duty Headlight Harness
I don't understand, what the big deal is about upgrading the light system with relays when your running Halogen headlamps? I have been running Halogen headlights for 7 years now on my 72 Chevy and have never had 1 single problem with the headlight switch, wiring harness or dimmer switch.
'72 Chevy SWB 350 Auto
'67 GMC LWB 350 4 speed
'70 Chevy 4x4 Stepside 350 Auto
Yellville, Ar. USA
BLACK AND BLUE 67-72 is offline   Reply With Quote
Old 12-24-2007, 06:14 AM   #14
Stocker
20' Daredevil (Ret)
Stocker's Avatar
I have also run halogens for many years without a harness or relay, and no problems. However, I'm sure the voltage at the lamps -- and therefore the light output -- is less than optimal. I just haven't gotten around to verifying it with a meter...
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 12-24-2007, 06:17 AM   #15
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
black and blue, Even with old T3 bulbs, the relays set up is a good idea. You increase the power to the bulb, which increases the light output. This is a noticeable difference. Ever notice at night you can tell who has an old car on the freeway from a few miles away... the yellowish orange light conpaired to the white light?
The amount of amps going thought the switches is an issue too, but it's an issue over time. Even with old school non hallogon bulbs, the amps going through the switches burns them up over time.
I have done the conversion, and see no reason personally to buy a kit. Too many people are afraid to modify there harness. A good repair/upgrade is just as good as unmodified. It's when you have 7 connections in a single wire wrapped with duct tape and wire nuts... that's when there's a problem.
Old 12-24-2007, 07:54 AM   #16
webbes
Lockdoc I do not but if you have any question just ask. I might be able to help
Old 12-24-2007, 08:51 AM   #17
LockDoc
LockDoc's Avatar
Thanks Bill. PM sent.
Sorry about the hijack... As a note on the OP's question, there's no doubt in my mind that the relay setup would take a lot of stress off of the light system, especially once the various connections start getting a little (or a lot) of corrosion on them. I know on a couple of older trucks I have had, after the lights have been on for a while the light switch under the dash got really hot. The relay mod should cure that. I plan on adding it to the white truck this spring.
LockDoc
LockDoc
Leon
Old 12-24-2007, 03:26 PM   #18
Steelawork'n
Just hang'n around
Steelawork'n's Avatar
...Yeah, and do you get tired of your truck casting a shadow from the newer cars on your tail. Higher powered headlights give you road dominance at night.
Driving a '68 Chevy C20 and a '93 Astro Van. Lots and lots of mileage that I deduct each year.
Steelawork'n is offline   Reply With Quote
Old 12-24-2007, 09:45 PM   #19
Firefighter
Steelaworki'n, nope I don't have that problem as a matter of fact I get the newer cars flashing their lights at me when I have them on dim already (Yes they are adjusted properly) LOL. My headlights on my 72 are even brighter than my wife's 94 Ford Escort and her 93 Toyota Camry, I have absoultely no problem seeing at night with them they give off a very bright white light. Now compared to my 70 with the old T3 headlights (which looks like I am using two very dim flashlights) it is definitely a drastic change.
Yellville, Ar. USA
Old 12-24-2007, 10:14 PM   #20
WorkinLonghorn
WorkinLonghorn's Avatar
Real trucks have 4 headlights and don't need all this crap.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme.
WorkinLonghorn is offline   Reply With Quote
Old 12-25-2007, 03:27 AM   #21
Andy4639
Old member
Andy4639's Avatar
WorkinLonghorn,
That's why they had four light's to begin with they couldn't see!
Old 12-25-2007, 05:31 AM   #22
Longhorn Man
try the real trucks, with 4 headlights, and relays. I hit the high beams and I can see into next week.
Yeah, chicks dig it.
Old 12-25-2007, 05:46 AM   #23
Andy4639
Old member
Andy4639's Avatar
Longhorn Man,
How long after they get their eye sight back do they dig it!
Old 12-25-2007, 05:49 AM   #24
Stocker
20' Daredevil (Ret)
Stocker's Avatar
I've had 'em both ways and while four lamps outperform two on high beam (especially with position-specific E-codes!), the larger reflector & lens on 7" lamps will throw more light on low beam than a comparable 5 3/4" lamp.
Now, a 7" H-4 high/low with separate high beam lamps would be the best of both worlds...
- Mike -
RIP El Jay
Old 12-25-2007, 05:52 AM   #25
Longhorn Man
LOL!!!
I prefer them slightly blinded... I can tell them I am real good looking and they won't question it. I tell them, "Picture brad pitt, but slightly better lookin and with a shaved head"
I have to blind them over and over sometimes.
