#576 |
![]() Join Date: Aug 2005
Re: Joined the Short Wheelbase Club *69 Tahoe Project*
Drivers side is 98% done. Still waiting on the correct bracket and another ebrake cable for the pass-side. BTW both cables are the same P/N even though NAPA calls out a driver and passenger side... The P/N I used is 94724 for both.
![]() ![]() ebrake cable routing; the length is perfect for this configuration: ![]() I'll add another clamp further forward on the trailing arm: ![]() I need to get some new retainer clips, but I think the OE style will work perfectly here: ![]() ![]() ![]() ![]() ![]() ![]() |
#577 |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Looking damn good I see your getting the rain too... How much block do you have in the rear..
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
#578 |
![]() Join Date: Nov 2006
This picture looks cool. I so much want to dislike big wheels but you guys sure make them look good.
Coming along nicely Frizzle! ![]() |
#579 |
Frizzle,
I just realized that's the same tire I'm running, different size though (275/45x20). Have you been able to put many miles on them yet? Just curious what you think. They were recommended by Jim at the TireRack so I figured they'd be good.
Jim '71 Blazer-Porterbuilt Dropmember C4/LS1/6L80E '57 VW beetle - Oct. 2006 Hot VW's pg. 87 - 350hp intercooled, turbocharged, EFI 2.3liter and 5spd in the works '87 BMW 325i - daily driver |
#580 |
Not many miles on them yet but so far so good. Low road noise. There are pretty well rated in all the reviews.
#581 | |
A guy with a truck
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
#582 |
Active Member
![]() Join Date: Oct 2006
I am also running the Parada Spec X great tires. I have nothing but good things to say about Yoko's I run them on my 4 banger, and my Tahoe as well.
#583 |
Looking good! Heck with as small as those brakes look I bet you will be able to change pads with out removing the rim
![]() Kevin LFD Inc. |
#584 |
On the fast track to nowhere..
Lol. Looks good, I LOVE big wheels
-Mike Owen- Norwood, Houston, Cecilia, Jackson, Monroe and counting |
#585 | |
I CAN'T WAIT TO GET MY TRUCK TOGETHER!!!!
#586 |
![]() Join Date: Apr 2005
FF, maybe I missed it, but how are you connecting the caliper to the brake lines? Is it a rubber line or a hard line? Thanks,
R/
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
#587 |
Just rerouted the OE hardline and used the thread adapters supplied in glock's bracket kit:
#588 |
Thanks, I was just making sure. All my other cars that had rear discs used a rubber line to go from the caliper to the axle. Since it uses a hard line, I'm assuming that part of the caliper doesn't move.
R/
#589 |
Gentleman Jim Driver
From that picture, that part of the caliper does move. I'd recommend getting some rubber or braided hose in there. It's a very small movement and might be ok, but you'd hate to work harden the steel and get a crack...
Joe '75 GMC Gentleman Jim '84 Chev C10 Short Wide - Super duper plain (manual steering, manual brakes, no dome light, no cig lighter) '85 Chev C10 Short Wide - Super plain Vortec 4.8 4L60E trans also: '81 K30, '83 C30 Crew Dually, '84 M1028 CUCV, '85 M1009 CUCV, another '85 C10 SWB, '89 R3500 Flatbed |
#590 |
Good call guys.
#591 |
A guy with a truck
W3rd. That's a floater...
#592 |
I've been trying to get the pics on page 1 and 2 for days now and all I get are red xs. Is any one else having the same problem? I can see the recent ones just not the earlier shots. Any one have a suggestion on how I can remedey this? Thanks, Michael
Michael 1971 GMC Suburban "Crusty" 2000 GMC Sierra 1500 2wd 1978 Scout II 1992 Passat Syncro |
#593 |
Michael,
I'm good but there are about 50 pics on the first page alone. Maybe your browser is timing out? Maybe a Ctrl/F5 will help or clear your temp files and try again. Dunno. Might be worth a try.
Jim '71 Blazer-Porterbuilt Dropmember C4/LS1/6L80E '57 VW beetle - Oct. 2006 Hot VW's pg. 87 - 350hp intercooled, turbocharged, EFI 2.3liter and 5spd in the works '87 BMW 325i - daily driver Last edited by babyblueoval; 12-28-2007 at 06:24 PM. |
#594 |
Here's the link to the photobucket account for the Burb. See subfolders on the left: http://s6.photobucket.com/albums/y23...69%20Suburban/
#595 |
Let's see, are you the one with the orange sweat shirt and matching hair?
I pictured you looking a bit older than that. ![]()
#596 |
Thanks for the link, Mike. I can see clearly, now.....
#597 |
I have a radical idea!
The name Frizzle Fry puts him at around 30-ish if I had to guess!
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! |
#598 |
BAM! I just checked the profile, and I was right! I'm guessing you were jamming to Primus in high school too!
#599 | ||
![]() Quote:
#600 |
FF, just wondering what you figured out for the rear brake hoses?
R
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 12-30-2007 at 10:27 AM. |
