Chevy One
Air Ride for the Rear?
Working on my 67 2WD, LWB with coils
![]() ARNOTT AIR SPRINGS 100 MM STRAIGHT SLEEVE AIR SPRINGS SERIES, PAIR 14" MAXIMUM EXTENSION! THESE ARE CUSTOM AIR SPRINGS DESIGNED FOR VARIOUS APPLICATIONS. PART# 10014VR. SPECIFICATIONS: Ride height 10" Max inflated diameter 5.7" Minimum compressed height 6" Full extension 14" 1/4" NPT air inlet 1500 lbs. @ 100 PSI. I don't know if the 1500 lb will be enough for towing? Any advice would be great. CO ![]()
Chevy One ![]() 67 1/2 Two-on-the-Floor 67 Nova 2Dr Sedan 03 Monte Carlo I'M NOT OLD, JUST A CLASSIC!!! |
Re: Air Ride for the Rear?
call clint up at kp components.. kpcomponents.com tell him what you are after and he'll figure everything up and set you up..866-575-4657
Trailing arm trucks should use a double-convoluted bag if it is being used in the factory coil-spring location.
Firestone 2500#/2600# & Slam RE 6's/7's can be used & they bolt-in w/minimal fab work.
Between Trucks...
Any details or links for this?
Beat it to fit, Paint it to match... ![]() |
There's a good installation 'how-to' in the FAQ's section from board member 'MrShelly'. It contains excellent pics which explain much more that typed words.....
I've purchased bags from both AirRide & Suicide Doors.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 12-25-2007 at 12:02 PM. |
#6 | |
Boosted Member
There didn't appear to be a bracket of any sort?? Thanks, Jeff
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq 1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift 1964 Buick Skylark Twin TURBO 383 LS pro-touring project 2014 VW Passat TDI - Daily Driver Turbo diesel 2015 Sierra Denali HD Duramax Turbo diesel 2016 Ford Explorer Sport - Twin Turbskis 2017 Polaris RZR Turbo 2014 Nor-Tech Center Console - Twin Supercharged Outboards TURBO ALL THE THINGS!! |
That's how mine are done-- no brackets. If you don't want to hassle w/drilling the required holes in the frame, it's easier to use a bracket on one end (mounting holes + air-fitting).
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 01-10-2008 at 04:42 PM. |
Boosted Member
I'm not afraid of cutting up my truck, believe me
![]() So Scoti, if you use the double convolute bags in the factory location, with no brackets, how high does the truck sit, aired up, vs, aired down, vs the factory springs? Is it pretty close to the factory ride height when aired up? Thanks, Jeff
