Old 12-26-2007, 05:52 AM   #1
jpabberton
madcow
jpabberton's Avatar
Strange Oil Leak???
I have a oil leak from the second bolt on the right front side of my intake manifold. Its a Edelbrock.
There is no leak when the truck is running and no leak when I shut it off on short drives. There is a small, about a tablespoon full drop of oil in the indent where the bolt screws in the next morning when I go out to look.
Could the manifold be cracked? I'm thinking about trying the non-hardening thread sealer. Any suggestions appreciated.
1970 SWB 4x4
350 4 speed
Factory AC
jpabberton is offline   Reply With Quote
Old 12-26-2007, 06:08 AM   #2
Chevy1TonFun
Grease Monkey
Chevy1TonFun's Avatar
Re: Strange Oil Leak???
Do you know if the bolts were sealed when it was installed? What you might want to try is take the bolt out and put ultra black sealer on the threads and that should fix your problem.
Tow Rig: 2012 Chevy 2500HD CCSB LTZ Z71 4x4 Duramax
Ultimate Offroad Build: 1978 Chevy Silverado K30 Crewcab Build Link http://67-72chevytrucks.com/vboard/s...d.php?t=654053
Mud Truck: 1972 Chevy Cheyenne K30 4x4, 468/400/205, D60/D70HD, 18" Custom Lift, 17x39" IROKs
FOR SALE http://67-72chevytrucks.com/vboard/c...ton-4x4&cat=12
Chevy1TonFun is offline   Reply With Quote
Old 12-26-2007, 06:54 AM   #3
cdowns
cdowns's Avatar
thats a normal leak when intake bolts are installed without thread sealer
Old 12-26-2007, 07:59 AM   #4
EAST SIDE LOW LIFE
EAST SIDE LOW LIFE's Avatar
Thumbs up Re: Strange Oil Leak???
I had the same problem with my Edelbrock manifold. I cured the problem with "Permatex" High Temp Thread Sealant.
esll.
Tomorrow is for doing today's stuff.
This truck has just the right amount of energy for me!
Author: Warren Lake .... (member)
EAST SIDE LOW LIFE is offline   Reply With Quote
Old 12-26-2007, 12:34 PM   #5
lbpd719
Zappaphile!
lbpd719's Avatar
clean it out really well before you seal up those threads =)
1969 C20 LWB Camper Special - The Beater..
1998 Cheyenne V6 - 4/6 Drop - For The Son
lbpd719 is offline   Reply With Quote
Old 12-26-2007, 02:19 PM   #6
68 P.O.S.
w/ cdowns & esll. I had the same thing happen to me when I changed my intake. I used the Permatex as well to cure it.
72 C10 lwb fleetside -stock 350/350 combo
68 P.O.S. is offline   Reply With Quote
Old 12-29-2007, 06:26 AM   #7
jpabberton
madcow
jpabberton's Avatar
Gracias to all the input.
1970 SWB 4x4
350 4 speed
Factory AC
Old 12-29-2007, 07:52 PM   #8
jpabberton
madcow
jpabberton's Avatar
I must be doing something wrong or cracking up .
When I took the bolt out to clean it the oil seeped out of the manifold gasket around the bolt hole and the one next to it (towards the front of the engine). What's throwing me off is that its leaking at the front highest point with the engine off while the engine slants to the rear of the truck. Could there be too much oil pressure? Maybe the bolts too long and is bottoming out in the well? Its a standard oil presure pump.
Anyway I used the high temp thread sealer and will wait until tomorrow to fire it up. Next I think I will replace the intake gaskets if this doesn't work. What a way to spend Christmas vacation.
1970 SWB 4x4
350 4 speed
Factory AC
