Old 12-26-2007, 04:48 PM   #1
bob1967
bob1967's Avatar
Right headlight bright, left one is not
I took my 67 for a drive to the post office and noticed my right headlight was bright, but my left was barely on. Anyone have a idea of what would cause this. I know my truck is hard to turn over even though the battery and the altenator, and belt are new. I was wondering if the voltage regulator might be the problem for the starting, but could that cause the headlight issue. I do know when I purchased the truck the previous owner did a good job at redneck rigging stuff, so a new wiring harness is in the future.
Thanks for any help
bob1967 is offline   Reply With Quote
Old 12-26-2007, 04:51 PM   #2
hvychve
To The Levy
hvychve's Avatar
Re: Right headlight bright, left one is not
Most likely, A ground problem.
hvychve is offline   Reply With Quote
Old 12-26-2007, 06:22 PM   #3
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Could just be the headlight bulb.I bought a truck once with the same problem and found that the PO had replced the brighter headlight with a "Plus 25" bulb.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 12-26-2007, 06:31 PM   #4
DavesRide
DavesRide's Avatar
groundLet me xpand. the ground for a circut lets the juice so to speak FLOW. A poor ground will create all kinds of strange happenings. Not at the battery, check the ground straps to your radiator support. Sand to clean metal and see what happens. Check the wires at the back of headlamp also.
R.I.P ESLL Even as the body dies the spirit lives on in the people you touched
DavesRide is offline   Reply With Quote
Old 12-26-2007, 06:50 PM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
a bulb on the way out will do that, i have to punch the passenger headlamp on the burb daily, and it brightens up after that too, every time.
A poor ground will do that, follow the wire from the headlight plug, and unbolt the wire and clean the metal on the rad core, and on the wire.
It could be a messed up power wire, but VERY unlikely. If the other 2 things check out OK, then inspect the other wires to the plug.
Old 12-26-2007, 08:25 PM   #6
webfoot
Poor ground x 14, I bet that might be the trouble with your starting. Scrape away rust/paint from under the ground area, and use star washers underneath.
Running in place gets you nowhere fast.
-me
1968 GTO 4-spd covnvertible
1970 K-20 4-speed, factory AC.
webfoot is offline   Reply With Quote
Old 12-27-2007, 04:19 AM   #7
LMN8UR
LMN8UR's Avatar
Try checking the connector at the headlight. I ended up replacing both of my connectors. AutoZone sells two connectors in a pack.
With your lights on, reach around behind the bulb and wiggle the connector.
Good luck!
72 Chevy C-10 Custom LWB
383 Stroker - Edlebrock Air Gap intake and 670 CFM Holley Street Avenger carb.
Hooker Comp Headers w/ X-Pipe and 2.25 duals
TKO-500 & 3.08:1 rear
I Love HEMI's, they're soft & chewy!
LMN8UR is offline   Reply With Quote
Old 12-27-2007, 05:29 AM   #8
cdowns
cdowns's Avatar
first place to go is clean the ground and while you're at it also clean the plug and bulb contacts and a light coat of dielectric grease does help
Old 12-27-2007, 02:38 PM   #9
69C10@16
x100 on the ground. lol. i had a ground go bad on my driver's side tailight when i first bought mine and it caused all sorts of issues. No brake lights, right turn signal caused all four to light as if emergencies were on, left turn signal activated my dashlights, my headlights flashed with my emergencies (relayed headlights so the small amount of current backflow tripped them). Anyways, it was messed up. Check grounds first.
69C10@16 is offline   Reply With Quote
Old 12-27-2007, 03:09 PM   #10
bob1967
bob1967's Avatar
Thanks for all the input guys, I replaced both headlight when I purchased the truck since the PO had a rag holding one in figured while down at the parts store buying adjusting screws might as well replace the headlights. I will check the radiator support ground I replaced the engine to frame and the cab to frame, but didn't know about the radiator support. Thanks again
Old 12-28-2007, 06:41 AM   #11
OrangeCrush1970
OrangeCrush1970's Avatar
Not sure about everything else, but I had the same problem w/ my headlight. Turns out it was a loose connection b/w the headlight and the wireing harness.
Rottenwood Garage
1970...71...72 C1500 aka Orange aka Sideshow Bob
540 BB Straub Roller Cam, AFR Magnums, XP 950, TKO 600
2 Tons of Fun
OrangeCrush1970 is offline   Reply With Quote
Old 12-28-2007, 08:24 AM   #12
NONHOG
NONHOG's Avatar
Good luck!
Just replaced my left headlamp only to find it was still inop . replaced dimmer switch still inop wiggled the connector behind headlamp and WORKS now
Still start with the grounds then search all the great headlight posts here !
"I feel the need for speed!"... as soon as I am done with my nap.
NONHOG is offline   Reply With Quote
