Old 01-12-2003, 08:10 AM   #1
dmurphy68
Question carb adjustment
I need to know what is the best way to tune a carb. I have an elderbrock (aka carter) just wanted to know what rpm you all are running in drive. and what are the two screws in front are for . my carb is a 1405 600 cfm. any help would be great
thanks
Darren
dmurphy68 is offline   Reply With Quote
Old 01-12-2003, 08:48 AM   #2
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
If you don't have the manual that came with it, go to www.edelbrock.com. From their home site, you can navigate around and get to the section that has all kinds of information, from technical stuff to tuning to parts info.
If you have never tuned a carb, I suggest you get that info, first. There are several ways to "adjust" the carb, i.e., using vacuum measurements, rpm's, etc.
The two screws you are referring to are for idle air. They can become a big problem if you damage them. The way they get damaged is by screwing them in, until they bottom-out with sufficient force to cause a groove to be cut at the taper (needle) end. IF that happens, you cannot get them to adjust properly.
As for an idle speed, I believe that you can generally go with an idle speed of 700 RPM's, in drive. That may mean about 750-850 RPM's, as it idles in neutral.....with a warm engine. If the engine is cold, and the choke is engaged, the idle speed will be higher, so wait until the choke is disengaged before adjusting the idle speed, or anything else, for that matter.
So, go to their website and download the info and PRINT a copy for yourself to keep on-hand.
Member Nr. 2770
Old 01-12-2003, 08:54 AM   #3
dmurphy68
Thanks alot ChevLoRay. the carb is bran new and i have the manual but never looked at it i just like getting helpfull tips on here I love this place the people the company makes me want to . ok thanks for you info i will get it adjusted and break in the new motor.
thanks
Darren
Old 01-12-2003, 11:38 AM   #4
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
I have also heard that you will want to run a fuel pressure regulator with that carberator. From what I have read on these and other boards, Edelbrocks don't like pressures above 4 lbs. and the stock fuel pump puts out 6.5 lbs. The result has been an engine that when you floor the throttle, falls flat on its face. I have one on my BB402 in my Blazer and it does seem sluggish to me, but I havn't done anything to it yet. I know there are several carberator guys on here that could explain this better than I can. WES www.ClassicHeartbeat.com
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 01-12-2003, 04:59 PM   #5
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Edelbrock comment....
My truck had a model 1401 Edelbrock, manual choke, performance jetting, when I bought it 3 years ago. Last year (2001), I replaced it with a model 1901, Q-Jet, with divorced choke. I am very happy with the swap. I still have the 1401, and a kit from Edelbrock to overhaul it. It ran so rich that the exhaust gas would bring tears to your eyes to be around it. It was running via an adapter on a stock, cast iron Q-Jet intake. I also changed to an Edelbrock Performer intake. It still ran rich with the 1401. The 1901, well let's just say that it is a much nicer arrangement, now.
Member Nr. 2770
Old 01-12-2003, 07:29 PM   #6
dmurphy68
yea she does run real rich i just thought it was an adjustment. man this sucks i hope i can get it to stop burning my eyes people must think i am crying all the time lol. thanks ChevLoRay for the info
Darren
Old 01-12-2003, 10:42 PM   #7
kaycee
kaycee's Avatar
I finally got rich 2
I never had a problem with mine until I put a K&N filter on it now it runs rich .I had prob. at first but finally got it tuned in(before the filter).I adjusted the air/ fuel and it is not as bad but still noticeable 2 me.The book help's allso as they mentioned b4
2001 Silverado K-1500
2005 FXDWG stage3
69 CHEVY Short/Step 327/4L60 373 posi
63 IMPALA 327/4L60
kaycee is offline   Reply With Quote
