Old 01-13-2003, 08:17 PM   #1
HotRod929
HotRod929's Avatar
Location: Bondurant, IA but in Worcester, MA for school
What torque converter stall speed should I get??
I have a 350/350 with 4.10 rear end and wanted to upgrade to a higher stall converter to improve the launch of my truck...I was wondering what stall speed i should get? Thanks
HotRod
1970 Chevy C-20
350 V-8
Turbo 350 w/ shift kit
Dana 60 w/ 4.10 gears AND Powr-Loc POSI
New Additions:
Summit Headers
135amp alternator
Proform HEI
Edelbrock 1406 600cfm carb
Sunpro Tach
Powr-Loc POSI
Edelbrock Performer RPM Intake
MSD 6A Ignition Box
AIM: HotRod929
Visit My Site: http://1970chevy.netfirms.com/
HotRod929 is offline   Reply With Quote
Old 01-13-2003, 08:38 PM   #2
crazy longhorn
Fabricate till you "puke"
What are the specs on your cam?
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 01-13-2003, 08:41 PM   #3
HotRod929
HotRod929's Avatar
its pritty close to stock i think.
HotROd
1970 Chevy C-20
350 V-8
New Additions:
Summit Headers
135amp alternator
Proform HEI
Sunpro Tach
Powr-Loc POSI
MSD 6A Ignition Box
AIM: HotRod929
Old 01-13-2003, 09:07 PM   #4
crazy longhorn
unless you are planning a larger cam down the road, you wont need too much extra stall. I would say something in the range of 2000-2200 should do you. Good luck.....crazyL
Old 01-13-2003, 10:54 PM   #5
bigjimzlll
bigjimzlll's Avatar
you want the stall to be around your max torque rpm..if you ahve astockish cam..max torque will be real low..1800-2200 and run out of rpm around 4000-4500..if put a 3000 stall, then you would only have a 1000-1500 rpm range to use..now if you had a cam with a rpm range of 2500-6000 rpm, and max torque at 3000, then a stall converter of atleast 3000 would be a good choice. Also the steeper gear and more torque the engine puts out the more stall you will get out of an advertised stall converter.
Jim
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications
click the clicky to join the site....
http://67-72chevytrucks.com/vboard/payments.php
67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44
Anderson,CA
bigjimzlll is offline   Reply With Quote
