Old 01-09-2008, 04:44 PM   #1
joemacho
joemacho's Avatar
Unhappy how to fix my frame 72 jimmy 4x4
well i checked my frame out were the powerstering gear box goes and is split where the bolts line up.and by the front leaf shackle is. wanted to know what is the best way to fix it.
joemacho is offline   Reply With Quote
Old 01-09-2008, 06:04 PM   #2
70gmcjimmy
GMCDAC
70gmcjimmy's Avatar
Re: how to fix my frame 72 jimmy 4x4
Hey joemacho, I assume you mean the power steering box, not pump.
If it is cracks, maybe welding, if the whole 3 bolt area is breaking out maybe a frame horn welded on but no one can really say without some pics.
Good luck---DAC
1970 GMC K5 Jimmy Custom 4X4 Mom's driver from 1971 to 2001!! Under rebuild!
1972 GMC C2500 Pickup owned since 1979 Needs a rest and refurbish!
1955 GMC 100 2nd design driven almost daily!
Rest In Peace Mom. "Dolly" 7/15/23 - 5/18/09
GMC driver for 30 years!
70gmcjimmy is offline   Reply With Quote
Old 01-09-2008, 06:28 PM   #3
WORNBRAKES
I have seen stiffener plates inside the frame rails and I have seen the horn replaced. Pics will help.
Mario and Mandy
Hughesville, MD 20637
69 C10 305/350
71 K5 Basket case
75 K10 Rescue **Parting out**
77 MG Midget **Parting out**
15 6.7L Cummins
WORNBRAKES is offline   Reply With Quote
Old 01-09-2008, 06:53 PM   #4
joemacho
joemacho's Avatar
so how do i post pictures i have them.
Old 01-09-2008, 07:04 PM   #5
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
to post pics, click the "post reply" button below this posting. Then click the "manage attachments" button and select your photos.
There are stiffener plates made for the second gen trucks as this is a common problem. I believe some have adapted them to fit the first gen blazer frame or you can just weld in some heavy-duty stock. Check CK5.com to find a vendor that sells the second gen stiffener plates.
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 01-09-2008, 07:33 PM   #6
joemacho
joemacho's Avatar
heres is the picture i hope and thanks again bouncytruck
Old 01-09-2008, 08:03 PM   #7
joemacho
joemacho's Avatar
heres another pic
Old 01-10-2008, 01:24 AM   #8
vtblazer
vtblazer's Avatar
Yep, there's trouble there...
Not a common problem on a 1st gen but being it's happened you gotta fix it.
Check out Off Road Design or DIY4x4, both great companies and products.
If there isn't a part already made, you could either replace the frame horn all together or make up some plates and weld em in.
OR, find another frame horn and make a plate using it. < (favorite choice IMO)
vtblazer is offline   Reply With Quote
Old 01-10-2008, 05:15 AM   #9
Yukon Jack
Yukon Jack's Avatar
Ouch - never seen a first gen have a break like that one. Like mentioned above, that happens often on the later frames. Good luck with the repair.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 01-10-2008, 05:51 AM   #10
bouncytruck
SKINNY TIRES RULE!
I'll agree, never seen that on a first gen. Might be a good time for a frame up rebuild. LUV has an incredibly nice rolling chassis he's thinking about selling.
bouncytruck 1972 K5
Old 01-10-2008, 05:52 AM   #11
MiniD
Mine was cracked in the exact location. This is usually the result of putting big tires on the rig and torque from the power steering box cracking the frame. There's a steering box patch kit that you can buy for extra support on the weld. It looks like you're may have already been repaired as you already have bolts in the core support bracket vs rivets. This would make the job MUCH easier.
I'd get this work done as soon as possible. You'd be amazed at how 1/16" of an inch of play right below your steering box will cause slop in your steering. Every time you turn the wheel it flexes there and 1/16" of an inch of flex (there) is about 1/8 of a turn on your steering wheel.
MiniD is offline   Reply With Quote
