Old 01-10-2008, 07:04 AM   #1
daveo68
daveo68's Avatar
Fog light Bumpers ?
Question for the guys with fog light bumpers. Where did you mount the switch?
68 C-10 Custom LWB
307 V8
Lexington,NC
davideowens@lexcominc.net
God Bless America
daveo68 is offline   Reply With Quote
Old 01-10-2008, 07:08 AM   #2
67ChevyRedneck
67ChevyRedneck's Avatar
Re: Fog light Bumpers ?
Under the dash. You can just barely see mine, it's below the gauge on the left, it glows when the key is on.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 01-10-2008, 11:17 AM   #3
Andy4639
Old member
Andy4639's Avatar
I tied mine to the park lamps so when I pull the head light switch for the park lights it turns them on. They are fixing to have a relay installed so it want pull through the head light switch.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 01-10-2008, 03:49 PM   #4
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
under the dash, next to a mini 3 gauge set.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 01-12-2008, 02:43 PM   #5
daveo68
daveo68's Avatar
Thanks for the info.
Anyone have pics showing the wire routing?
Thanks again,
Dave
68 C-10 Custom LWB
307 V8
Lexington,NC
God Bless America
Old 01-12-2008, 07:36 PM   #6
daveo68
daveo68's Avatar
ttt
68 C-10 Custom LWB
307 V8
Lexington,NC
God Bless America
Old 01-12-2008, 07:49 PM   #7
Select
Friday's Toy
Select's Avatar
I tied mine in with my fuel pump for the time being. I'll end up with them on with the parking lights after I get around to installing my wiring harnesses.
68 C10, SWB Fleetside with a 454, Turbo 400 and 4.11 posi....Exxon/Mobil loves me.
2009 Jeep Rubicon
2011 Powerstroke FX4 (totaled)
71 C10, SWB Fleet with factory tilt
72 LWB C10, 350 700R4 with factory tilt
Select is offline   Reply With Quote
Old 01-12-2008, 08:00 PM   #8
68GMCCustom
I wound up running the switch wiring thru the fire wall on the passenger side. That way it was a clean install for the relay to go on that side and then the feed to the lights.
You have to install the light harness like an L, so you have to decide whether the wiring under the hood is going to be on the driver's, or passenger's side... along with the relay, and then from there into the cab, and on to the switch.
Kurt -
Old 01-13-2008, 03:20 AM   #9
mrein3
mrein3's Avatar
Good idea by Andy4639 to run them off the parking lights. However I like to control them seperately. I made a panel that I put under the ignition switch. The top button is back up lights (I bought the truck with toggle controlled back-up lights but someday will go back to controlling them through the steering column). Bottom button is lights in the bumper.
The 12 volts from the switch goes out through a hole by the fuse panel where I run a bunch of other stuff I've added. The relay for the lights is on the LF fender. The switch turns on a relay that dumps 12 volts right off the battery.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 01-13-2008, 04:01 AM   #10
haysonj
haysonj's Avatar
The red switch above the AC vent wired through the ignition so they cannot be left on. The relay is on the radiator support to the left of the daytime running lights.
69 Chevy 4x4 383 Power
haysonj is offline   Reply With Quote
