01-11-2008, 03:55 AM | #1 |
cab supports
Starting to put my 72 jimmy back together, im in need of front cab supports, where can i get these, i have seen the slip on but i would like replacements, also is blazer/jimmy cab supports the same as for trucks. Also wanted to see pics of custom rear floors as Im wanted to do something different than metal. Thanks for any help.
01-11-2008, 04:18 AM | #2 |
Re: cab supports
There's a couple of vendors on the board that could help. GMCPaul I think is one. Then there's always LMC.
1969 K10 - V8, 465, 205, 12 bolt, D44 2002-current 1969 K20 - V8, 465, 221, Eaton, D44 2012-current Nothin' but drums on all 4 corners! past horses in the stable 72 C10-short step (97-02), 68 C10-long fleet (06-12) |
01-11-2008, 05:38 AM | #3 |
Re: cab supports
Give Tri-Pro a call, nice guy. They are located in NJ.1-866-754-9112, Jon can tell you of the closest distributor to you, it may well be Tim at Christians. I've used his stuff thruout and had no problems. Truck and Blazer/Jimmy are the same... J.
01-11-2008, 06:22 AM | #4 |
Re: cab supports
X2 on using Tri-Pro.
Just received 2 rockers/inners and both floor pans and they look right and seem to be fairly heavy gauge metal. Last edited by vtblazer; 01-11-2008 at 06:22 AM. |
01-11-2008, 06:31 AM | #5 |
Re: cab supports
When I was over there 3 weeks ago, I picked up a lot of body panels. All of them were of the highest quality, and heaviest gauge metal in the industry. Jon assured me that GM would not allow junk to be reproduced with GMC's name on it. All parts are reproduced to GM specs.
