Old 01-11-2008, 06:09 PM   #1
skokie
skokie's Avatar
How do you remove the collar from a tilt column
How do you remove the top collar from a tilt column? Will anything fall out? I will be installing a new turn signal switch.
RIP to my son Dylan. 5/17/2002 - 8/18/2018
If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started.
https://slothforpedcancer.org
68 build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=223234
skokie is offline   Reply With Quote
Old 01-12-2008, 09:22 AM   #2
skokie
skokie's Avatar
Re: How do you remove the collar from a tilt column
Ttt
68 build thread
Old 01-12-2008, 09:28 AM   #3
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
Here's all the pieces if they fly out everywhere.LOL
sneakysnake is offline   Reply With Quote
Old 01-12-2008, 10:19 AM   #4
john
member #16
john's Avatar
If you are referring to the cover piece, it presses on. Remove levers and use something soft and tap it off. I use a small piece of wood in the turn signal lever hole.
john is offline   Reply With Quote
Old 01-12-2008, 01:57 PM   #5
skokie
skokie's Avatar
Ok will give that a try. Thanks John.
68 build thread
Old 01-12-2008, 02:06 PM   #6
71swb4x4
71swb4x4's Avatar
I used a rubber hammer and hit it lightly while turning it over and over. Eventually it comes off.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 01-12-2008, 02:08 PM   #7
skokie
skokie's Avatar
So its a press fit?
68 build thread
Old 01-12-2008, 02:14 PM   #8
71swb4x4
71swb4x4's Avatar
If you are talking about the piece that is labeled "cover" above, then yes it is a press fit.
Old 01-12-2008, 02:18 PM   #9
JimKshortstep4x4
It is a press fit. The service manual shows using a puller that catches the lip on the inside and pulls against the shaft.
I remove the tin housing by tapping it off after soaking the press fit area with penetrant since I don't have the tool that the manual shows. I have not run across one that cannot be easily tapped off.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 01-12-2008, 07:39 PM   #10
AuggieStyle
AuggieStyle's Avatar
AuggieStyle is offline   Reply With Quote
Old 01-12-2008, 07:44 PM   #11
skokie
skokie's Avatar
Originally Posted by AuggieStyle View Post
I liked that one to
68 build thread
