Old 05-18-2002, 10:31 AM   #1
>X<
registered IWATA user
>X<'s Avatar
Post should i replace any rivets on my frame?
about to paint my frame, when i buy the paint. should i need to replace any rivets? i am taking apart the trans crossmember to blast under it, i am gonna put it back together with some grade 8 bolts, but shold i have to do this to any other part o my frame, has anybody replaced any rivets?
-'63 Ford Fairlane 500 coupe, v8, auto, faded and rusty. awaiting built roller 302 and some flat black
-'99 Honda Prelude. vtech/5spd. no pipe, no intake, bone stock. awaiting new top end.
-01 GMC Yukon SLT 5.3 dented and scratched with a noisy tranny.
Take off that Von Dutch hat before i stab you with a 000 Mack.
>X< is offline   Reply With Quote
Old 05-18-2002, 10:50 AM   #2
Zkast
Zkast's Avatar
Post
I wouldn't unless you see signs of slipping or looseness. If there are markings around the head of the rivet where it looks like it has become loose and started moving around then cut it out and replace with a bolt....
Pictures and more...
piston@zkast.com
'71 LWB
350/350T, PS/PB
Special options? Yes, RUST... Need some?
Garrett - Olathe, Kansas
Zkast is offline   Reply With Quote
Old 05-19-2002, 03:05 AM   #3
Duallie
Duallie's Avatar
Post
If you have power steering, take a close look at the frontmost crossmember rivets near the steering box. Half of the frames I work on have torn the crossmember itself at the rivet.
I welded my C30 frame crossmember.
Just as if I knew what I was doin'
Duallie is offline   Reply With Quote
