Old 01-14-2003, 06:33 PM   #26
Mike C
Mike C's Avatar
All excellent advice. Used furnace is pretty much worthless. If you have gas, I would take advantage of it. I'll probably put my electric furnace in my shop when I upgrade my house to a heat pump, but who knows when THAT will be. In the mean time, I just use the radiant barn (as they call it...Hmmm. ) heater if anything.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 01-14-2003, 06:41 PM   #27
Yukon Jack
Yukon Jack's Avatar
I'm surprised you even need a heater down in that sunny, bikini clad Texas climate of yours. Btw, tell them college girls I say hello!
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 01-14-2003, 08:28 PM   #28
weasel29gm
SLOW BUT SURE,BUT CLOSER
Jack, have you thought of a dual air- heat unit, gas-pack. self contained, high low any where. I got on for the house, $ 2600 installed. But if you can get someone to wholesale it to ya. Appx. $11-1300 do your own ducts you'd have heat & air. Do good on a 2400 sq ft garage. Or try 2 4-5 plaqe ventless nat gas heaters on each side or end of it. Use as needed,cost what 2-3 hundred? I"m goin' with 2 3- plaqe, one up front and the other at the back. My garage is 14 by 32.
69 C-10, OWNED 38YRS... 350 over 30, 350 Turbo, 3:73 Posi P/S, P/B Black with red and black int. ''LOVE THESE OLD ''TRUCKS.......
weasel29gm is offline   Reply With Quote
Old 01-14-2003, 10:34 PM   #29
Mike C
Mike C's Avatar
Chances are your name won't come up when I'm talkin' with girls... Yea, I seldomly use the heat unless I am doing something that is temp sensitive. (Paint or drywall, or it is REALLY cold-ouside temp in 20's or 30's.) Until I get the whole thing insulated, it's really hard to keep temp up. I have two whirly-birds, 3 gravity vents, and two gable vents which really lets the heat out! Also have non-insulated garage doors (4 of 'em 9'x7', I just couldn't afford insualted, it doubled the price.) Whatever you decide, hopefully you have been steered from the kerosene....
44 Willys MB
52 M38A1
64 Corvette Coupe
Old 01-15-2003, 04:24 AM   #30
O'l Buck
Recovering Truck Driver
O'l Buck's Avatar
If your barn is anything like my barn, use the house heater, a big wood burner and 2 space heaters.....my barn needs help bad!!!!!.....I'm gonna have to try the ATF and diesel mix in my knipco heater, I just use #2 diesel in it, but diesel smoke makes me horny, so my wife won't let me work in the barn much in the winter.......LMAO
67 K-20 350, SM465, Eaton rear, 4.56 no spin option
00 Dodge 2500 4x4, 24V cummins, 5 speed
Chad
South Central Nebraska
O'l Buck is offline   Reply With Quote
