Old 01-16-2008, 06:43 PM   #1
rick0312
rick0312's Avatar
Inner/outer Tie rods question
Hey Guys just got all new inner and outer tie rods. Only problem is they all look to be the same. Is there any difference between the inner and outer tie rods on a 69 c10 1/2 ton? Can you use a outer tie rod as a inner tie rod? or did they screw up my order......thanks ... rick
rick0312 is offline   Reply With Quote
Old 01-17-2008, 05:07 PM   #2
rick0312
rick0312's Avatar
Re: Inner/outer Tie rods question
ttt
Old 01-20-2008, 03:22 PM   #3
rick0312
rick0312's Avatar
this must be a very stupid question.....sorry!
Old 01-20-2008, 03:41 PM   #4
Jim_PA
The threads are different. I believe the inners are RH thread, and the outers are LH thread. Not sure about any obvious physical appearance differences.
Jim_PA is offline   Reply With Quote
Old 01-20-2008, 10:37 PM   #5
kenm78
Broken Down
kenm78's Avatar
The outters are the short ones and are have right hand threads, the inners are about 4 inchs or so longer and have left handed threads. I just repalced mine so its fresh in my head
kenm78
1982 Chevy 4X4
Project truck
“It’s better to keep your mouth shut and let people wonder about your ignorance, than open your mouth and reveal all doubt”
kenm78 is offline   Reply With Quote
Old 01-20-2008, 11:50 PM   #6
68gmsee
Active Member
68gmsee's Avatar
Nope, it's not a stupid question. From what I've found out about this site is that all questions are legit. Just have to find the person or persons that knows or remembers the answer. Sometimes it takes a couple of tries to jog someones memory also, so you did the right thing.
68gmsee is offline   Reply With Quote
Old 01-21-2008, 12:37 AM   #7
stope4
I agree with Kenm. Inners are longer than outers. If they look the same, something is wrong.
Inner is moog part number es403l
outer is moog part number es415rl
sleeve is moog part number es2004s
stope4 is offline   Reply With Quote
Old 01-21-2008, 11:34 AM   #8
rick0312
rick0312's Avatar
thanks alot!
Old 01-21-2008, 01:17 PM   #9
kenm78
Broken Down
kenm78's Avatar
Your welcome hope you get it going!!
kenm78
1982 Chevy 4X4
Project truck
Old 01-21-2008, 08:36 PM   #10
68C15
blood type; Retumbo
68C15's Avatar
do you know how to set the toe close to get it to the alignment shop?
68C15 is offline   Reply With Quote
Old 01-21-2008, 11:27 PM   #11
ChevyC102007
ChevyC102007's Avatar
Count the number of turns it takes to get the old tie rods out, then put the new ones back in the same number of turns. That should get it back as close as possible to get the truck to the alignment shop. Ive got my drivers side tie rods sitting in the truck ATM just waiting for a break in the weather to get them put on (or at least until my friend gets back so I can use his garage and AIR tools ) Hope this helps.
"When you were born, you cried and the world rejoiced.
Live your life so that when you die, the world cries and you rejoice."
[Cherokee saying]
2001 Dodge Ram Sport 1500 4x4. (old ride)
1987 GMC V1500 Sierra Classic ("new" ride)
ChevyC102007 is offline   Reply With Quote
