Old 01-18-2008, 04:42 AM   #1
killa98z
1967 steering question
i have a 67 k10 and i want to lift it 4 in but what can i do about the steering because i have the box that swings front to back not side to side with a closed knuckle front diff.will anything have to be done to steering thats in the truck or would it have to be converted to a new style thanks john
killa98z is offline   Reply With Quote
Old 01-18-2008, 11:56 AM   #2
goldengoat2
Re: 1967 steering question
My 67 3/4 ton had a 4" lift when i bought it with stock non power steering , the steering arm hit my tire when making a turn, 33or 35" tires, I installed a disc brake front axle and added power steering....BIG DIFFERANCE!! way better.
To answer your question the stock steering still worked with the 4" lift, but watch your tire size
65 tripower conv 4spd gto, 66gto, 67 gto
65 lemans conv 4spd
69 firebird conv.
67 c20 4x4
goldengoat2 is offline   Reply With Quote
Old 01-18-2008, 12:55 PM   #3
killa98z
thanks anyone else got any more info to help me out
Old 01-18-2008, 11:30 PM   #4
1969K10
1969K10's Avatar
All chevy 4X4 trucks have a steering box that swings front to back. If you want to go side to side, get a 2WD steering box and do a cross-over steering set-up. It's a lot of work if you're not going to need it. but you can run your 4" lift w/o converting to the cross-over steer.
1969 K10 - V8, 465, 205, 12 bolt, D44 2002-current
1969 K20 - V8, 465, 221, Eaton, D44 2012-current
Nothin' but drums on all 4 corners!
past horses in the stable
72 C10-short step (97-02), 68 C10-long fleet (06-12)
1969K10 is offline   Reply With Quote
Old 01-19-2008, 08:18 AM   #5
killa98z
do they make a power steering box that swing front to back and if so what years did they come like that
Old 01-19-2008, 08:53 PM   #6
Blazer1970
Blazer1970's Avatar
All full size GM 4X4s, 1969 to 1987 ('91 for Suburbans and Blazers).
Blazer1970 is offline   Reply With Quote
Old 01-19-2008, 10:51 PM   #7
FormerMember
I'd also suggest a dropped pitman arm or raised steering arm to compensate for the 4" lift. Not really required but will ease up on the steering angles a bit.
FormerMember is offline   Reply With Quote
Old 01-19-2008, 11:41 PM   #8
Yukon Jack
Yukon Jack's Avatar
Grendel, I don't think anyone makes a raised steering arm for the closed knuckle axle that he has. When I did my lift on my 69 K20, also closed knuckled, I had to go with an adjustable drop drag link to fix my steering issues.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 01-19-2008, 11:57 PM   #9
FormerMember
Then I go with the dropped pitman arm. An adjustable draglink works as well.
I haven't checked, but I think they make spacers for the steering arms that go onto a closed knuckle?
Old 01-23-2008, 11:33 AM   #10
killa98z
i could find anything that helps my steering arm hangs down and swings front to back i could find any other years except for 67 that have this style any help
Old 01-23-2008, 01:15 PM   #11
msgross
msgross's Avatar
you'll also have to deal with the frame difference if you go with a newer PS box. 67-68 frames were flat behind the box and 69 and up frames had a "dimple". You can search this board for some fixes that guys have done. I plan on making a bracket to hold it... Not a simple bolt on though...
I suggest finding a newer axle to gain disc brakes, raised steering arm and get it done all at once. Just be sure to match the gear ratios. The axle is a bolt in fix but then you have to deal with the master cylinder issue... This is how one fix creates multiple fixes and sooner or later your truck is in 5,000 pieces!
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 01-23-2008, 02:59 PM   #12
Blue_71
Bloo
Blue_71's Avatar
just a quick pic to show the different steering gears, referenced from the latest LMC Truck catalog
ASE Master Certified-GM Trained-Mechanic
1968 Chevy C30 157" WB Wrecker
1969 Chevy CST/10 SWB
1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed
1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205
1974 Chevy Custom Deluxe/10
1979 Chevy Custom Deluxe K10 farm truck beater
1989 Chevy K2500
Originally Posted by Alan Jackson, Cause I'm a country boy
35s whinin on the asphalt, grabbin mud, throwin up some red dirt
R.I.P. Michael Stilts... I will always love and miss you brother! (9-12-80, murdered 4-9-05)
Blue_71 is offline   Reply With Quote
Old 01-23-2008, 06:11 PM   #13
earl87gta
earl87gta's Avatar
I have 6in of lift and the stock steering arm on my 68 and I dont have any trouble as long as its not flexed out I cant turn as sharp as i would like but Im changing to cross over now that Im puting the d60 in it so I shouldnt have any trouble.
Earl
68 2500 4x4 GMC Burb
earl87gta is offline   Reply With Quote
