Old 01-18-2008, 10:06 AM   #1
afoshie
Ram Horn Manifolds
Just wanting to double check a part number if anyone could help. I am wanting to run ram horns on my truck and am looking for the 2.5in outlets. I belive i found the correct part numbers but not real sure could anyone double check and help me out. thanks in advance.
3797901 3797902
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=265847
afoshie is offline   Reply With Quote
Old 01-18-2008, 11:54 AM   #2
Sweet72
Sweet72's Avatar
Re: Ram Horn Manifolds
Did a little google search and found that Year One lists those part #'s for 1962 & 63 Corvette and full size chevrolet with 327ci and they do have 2 1/2" outlets. They both have a bracket cast in for accessory mounting, which could be cut off. I have considered using them myself, but have heard that since they dump straight down, they will interfere with the motor mount towers. Maybe someone who's used them can verify this.
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction.
Sweet72 is offline   Reply With Quote
Old 01-18-2008, 08:30 PM   #3
Blazer1970
Blazer1970's Avatar
I used 2 3797901s on my truck. The manifolds are the same left to right except for the generator mounts which you will not use anyway. I cut them off and ground them smooth. Dorman sells these manifolds new now, so you should be able to buy new ones at any good parts store with a little digging.
Blazer1970 is offline   Reply With Quote
Old 01-19-2008, 12:32 AM   #4
hyarbour
I think the ones sold by Dorman are 2" outlet
hyarbour is offline   Reply With Quote
Old 01-19-2008, 07:07 AM   #5
Blazer1970
Blazer1970's Avatar
That is possible. I am not 100% sure. Also, my Blazer is 4WD so the straight down dump manifolds fit like factory.
Old 01-19-2008, 07:25 AM   #6
neonlarry
neonlarry's Avatar
IIRC the drivers side MM bracket needs a little triming to clear.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 01-19-2008, 10:36 AM   #7
JAKES 68GMC
Aluminum slot wheels rule...
New 2 1/2" outlet Corvetter ramhorns can be found online for $75 a piece, or 150 for 2 with hardware. I can't remember the website though.
JAKES 68GMC is offline   Reply With Quote
