Old 01-20-2008, 03:20 PM   #1
rick0312
rick0312's Avatar
Fuel Line Size?
Hey guys,
I am in the process of a motor upgrade from a 2bbl 305 to a 4bbl 250hp 350. The original fuel line from the in cab gas tank is a 5/16 line. I want to replace this line with a new one. Is a 5/16 line acceptable for my new 250hp motor, or should i use a 3/8 line?....thanks.....rick
rick0312 is offline   Reply With Quote
Old 01-20-2008, 07:59 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Fuel Line Size?
if you had a 305 V-6, then you should have the 3/8 line.
5/16ths will be plenty.
Old 01-21-2008, 12:15 AM   #3
BLACK AND BLUE 67-72
Firefighter
BLACK AND BLUE 67-72's Avatar
Re: Fuel Line Size?
For the 350 go to 3/8" line.
'72 Chevy SWB 350 Auto
'67 GMC LWB 350 4 speed
'70 Chevy 4x4 Stepside 350 Auto
Yellville, Ar. USA
BLACK AND BLUE 67-72 is offline   Reply With Quote
Old 01-21-2008, 11:35 AM   #4
rick0312
rick0312's Avatar
Re: Fuel Line Size?
yea, 3/8 seems the way to go, but will I have to change the sending unit?
Old 01-21-2008, 11:39 AM   #5
rick0312
rick0312's Avatar
Re: Fuel Line Size?
Andy, the 305 was installed by PO donated from a 76 camaro. I pulled a 5/16 fuel line out of the frame rail, so i assume that the truck originally had a inline 6 in it. I thought all V8's came with a 3/8" line?...Rick
Old 01-21-2008, 12:06 PM   #6
Sweet72
Sweet72's Avatar
Re: Fuel Line Size?
Nope, the small v-8 and I-6 had 5/16 lines. Stay with what you have. The 350's did have 3/8. I don't think you need 3/8 unless you're feeding 350 plus hp. MHO
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction.
Sweet72 is offline   Reply With Quote
Old 01-21-2008, 12:11 PM   #7
rick0312
rick0312's Avatar
Re: Fuel Line Size?
thanks
Old 01-21-2008, 01:02 PM   #8
DieselEater
DieselEater's Avatar
Re: Fuel Line Size?
I feed a dyno'd 500HP BBC with the stock fuel line from a 69 frame with a 292.....No need for upgrade...
A......
69' 3/4 4X4
470ci BBC
700 HP....
D60/14bolt
205/465
http://profile.myspace.com/index.cfm...ndid=127691959
DieselEater is offline   Reply With Quote
