01-22-2008, 01:40 AM | #1 |
Rear shock relocation
I am lowering my 72 c-10 project 3 inches in the front and four in the rear. I have found some shock relocators for trucks lowered four or more inches in the rear and want to know if others have done this and is it worth it.
.....also I am wondering about extending the rear panhard bar to the far other side connecting to the opposite trailing arm instead of the diff. I found both of these new options on the classicperform.com web site that came to me from this site. Anyone that has done this I would be interested in hearing about it. Thanks |
01-22-2008, 02:07 AM | #2 |
Re: Rear shock relocation
shocks are most efficient when they go straight up and down the more angle that they are mounted at the less effective they are
01-22-2008, 02:20 AM | #3 |
I did both on my '70 stepside. Definitely made a night and day difference. Planning on adding a rear swaybar kit. It is lowered 4.5" in the front and 7" in the rear.
01-22-2008, 02:31 AM | #4 |
Old member
I just installed the new adjustable bar but haven't drove it enough to tell a big deferance yet. I cut some 3" angle at work the other day to make the relocator for the shocks. I haven't installed them yet, because I need longer U-bolts.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
01-22-2008, 04:57 AM | #5 |
With a little modification, you can modify the stock brackets to relocate the shocks just like aftermarket brackets do.
Flip the lower brackets from side to side (EX: The top of the bracket that was on the drivers side would now be the bottom of the pass side). It requires flattening out the bracket some or you can make spacers, you just want it will lay flat on the trailing arm. This is worth about 1.5" of shock travel. The uppers you re-drill the shock bolt hole higher up on the side of the original bracket & then trim the excess metal off so the shoulder of the shock doesn't hit the bracket. This one will also get around 1.5" of additional shock travel depending on how high the hole is re-drilled.
01-22-2008, 05:56 AM | #6 | |
BB70c10
01-22-2008, 05:57 AM | #7 |
Old Skool Club
I used ECE shock relocators on mine, with the adjustable track bar. Best riding truck I've ever owned/driven.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
01-22-2008, 07:34 AM | #8 | |
Old member
SCOTI,
Even if you don't straighten it out how do you get the u-bolts to work. Mine were at least 2" short. I like a full nut when done. I ended up getting some angle iron at work and going to make some. As far as the upper's I haven't looked at that yet. I hope the longer angle iron will take care of it.
01-22-2008, 08:14 AM | #9 | |
In the stock installed orientation, the lower shock bolt is above the bottom of the trailing arm. After the 'flip' the shock bolt hole is below the trailing arm; but still no lower than the u-bolts.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 01-22-2008 at 08:18 AM. |
01-22-2008, 08:31 AM | #10 |
I used the ECE setup and it worked quite well.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
01-23-2008, 12:51 AM | #11 |
COOL!! Thanks for the advice on this. I will try to modify the lowers like you advised SCOTI. I just was not sure where the relocation was. I thought at the top but it seems that most is near the bottom.
The next question would be what amount of drop do you use for ordering shocks with this relocation done?? BB70c10 I am just trying to get my chassis done for the autorama in Feb and will not have my body on for some months. Hopefully this summer though. I will post some picts when it is done though. Last edited by s_nova69; 01-23-2008 at 12:52 AM. Reason: make it more clear of needs |
01-23-2008, 01:01 AM | #12 | |
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 01-23-2008 at 01:02 AM. |
