Old 01-22-2008, 03:07 PM   #1
ANTSBAGGEDK5
81-82 2wd blazer owners I need your help!
I purchased a 87 4wd blazer to convert to 2wd, but this blazer has no axles
under it, so I have no idea where to place my rear axle. I searched all the local junk yards= no blazers!
What I need is for somone to crawl under the rear of their blazer and measure from the end of the frame to the center of the rear axle
Thanks you guys I realy appreciate your help.
Anthony
ANTSBAGGEDK5 is offline   Reply With Quote
Old 01-23-2008, 04:03 AM   #2
kevinr1970
Re: 81-82 2wd blazer owners I need your help!
Maybe I am not understanding what you asking but the axle should have locating holes on the spring perches to match the locating pins on the springs.
2009 Honda Fit CfC (bsf 44.9 mpg)
2000 Tahoe Limited
1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below
1991 GMC CrewCab Dually 4x4, just going to fix things up for now
1982/1989 K5/GMC Jimmy 2wd
1987 GMC 1/2 ton swb 2wd Crew (sold)
kevinr1970 is offline   Reply With Quote
Old 01-23-2008, 07:22 AM   #3
lolife99
67-72 parts collector,…
lolife99's Avatar
If you're building a custom rear suspension,... just center the rear wheel in the wheel opening. Otherwise a stock leafspring will locate the rear housing.
Keith
Convert to disc brakes.
Old 01-23-2008, 11:25 AM   #4
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
Just measure 106.5" from the center of the front wheels...
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
