Old 01-23-2008, 03:12 AM   #1
OrangeCrush1970
OrangeCrush1970's Avatar
Coil Spring lowering clamps
Has anyone ever used these to raise or lower the stance of your truck?
http://www.graystonengineering.com/suspensionpage.htm
I was considering this to be a cost effective method of lowering 1" in the front and 3" in the rear (if that's possible with these clamps).
Rottenwood Garage
1970...71...72 C1500 aka Orange aka Sideshow Bob
540 BB Straub Roller Cam, AFR Magnums, XP 950, TKO 600
2 Tons of Fun
OrangeCrush1970 is offline   Reply With Quote
Old 01-23-2008, 04:08 AM   #2
yotaforce
Re: Coil Spring lowering clamps
Don't do it. Dangerous.
yotaforce is offline   Reply With Quote
Old 01-23-2008, 04:41 AM   #3
SactoJim
SactoJim's Avatar
Certainly not the best way to do it, but I've used them in the past and had them on for a couple years with no problems.
I don't quite see the "danger"....maybe with installing or removing them.
if they were a big danger, the bigger parts stores wouldn't carry them due to the liability issue.
72 Cheyenne SWB Fleet
Nut & bolt frame off in progress...99.9999%
- supercharged 383
- 4 wheel discs
- relocated fuel tank
My Build Thread
SactoJim is offline   Reply With Quote
Old 01-23-2008, 05:32 AM   #4
betonj97
I've also ran them......they are what you pay for....not bad till you can for the cash.
Chillin
betonj97 is offline   Reply With Quote
Old 01-23-2008, 06:39 AM   #5
shifty
Questionable
shifty's Avatar
Those things are so F*ing stupid. the previous owner stuck two pairs of those things on each spring on my VW GTI and it made for the absolute worst F*ing ride on the planet.
Use at your own risk. I'll never put those on any of my rides.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 01-23-2008, 08:11 AM   #6
crazy longhorn
Fabricate till you "puke"
For an inexpensive drop that wont give any problems, you can run a 2" block/longer U bolts in the rear of a coil spring setup, & cut 1 coil of the bottom of the front springs(2- 2 1/4" drop). you will need to trim the bumpstops up front, & use a tractionbar snubber for the new stops. This may not be the stance you are looking for, but the ride wont suffer from it....crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 01-23-2008, 11:15 PM   #7
OrangeCrush1970
Thanks guys, I think Im just going to save the $$ and get some new springs.
Rottenwood Garage
2 Tons of Fun
