How do you get this trim off?
Is there a special way or do you just pry it off with a screw driver or something
Its no disgrace being poor. Its just inconvenient. |
![]() Join Date: Jul 2007
Re: How do you get this trim off?
maybe there are some screws/nuts on the inside of the cab?
Shadetree Mechanic
I believe that trim is held on with double sided foam adhesive.
If you are going to pry it off with a screwdriver, i suggest you first heat the metal surface its glued to as best you can from the inside of the truck. Sorry for misdirection, I have not removed this molding before, just the side moldings....glad someone spoke up with experience.
Dave M. (Hacksaw) 86 C10 Scottsdale LWB, 4.3L, Edelbrock 1904, K&N, 700R4, 3.08 Auburn Performance 89 GMC S-15 Extended Cab 4x4, 4.3L, FI 98 K1500 Xcab, 5.7L, 3.43 Gov-Lok Last edited by 86-C10-V6; 01-25-2008 at 06:09 AM. |
yeller
Corner pieces are held on with speed nuts, inside the cab. DO NOT try to pry them, you'll break the trim or the studs for the trim...and damage the center section.
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
#5 | |
- Dave
2003 Silverado K1500 Z71 - Arrival Blue 1973 K5 Cheyenne Blazer 350/TH350/NP203 Kids Trucks:92 K1500 Blazer 5.7/700R4 4" lift. RETIRED: 1980 Scottsdale 4x4 Founding Member: "TILT WHEEL BELLY." Club |
nuts on corners and slide off back trim......
Thanks guys
