Old 01-27-2008, 11:11 AM   #1
468BIGBLOCK
MEMBER OF THE JUNK MAN CLUB
468BIGBLOCK's Avatar
GEN 3 5.3 6.0 QUESTIONS.headers,a.c,cruise.
I will be installing a gen 3 engine in my 70 gmc. what is everybody doing about the speedo? i want to use stock gauges.also how are they making the cruise work? also who makes a nice set of headers?,and can you use the stock gm compressor with a aftermarket a/c set up? i will prolly be going with a cable type throttle body. THANKS!!
I LIKE 67-72 CHEVYS, I HAVE OWNED OVER 150 OF THEM IN THE LAST 25 YEARS..
468BIGBLOCK is offline   Reply With Quote
Old 01-27-2008, 11:18 AM   #2
dan42
dan42's Avatar
Re: GEN 3 5.3 6.0 QUESTIONS.headers,a.c,cruise.
You've been pretty quiet for being here for 7 years. 62 posts? Longhorn man does that at lunch. There are a lot of guys doing this, and it sounds like from what I read there are millions of options depending on the cash flow. Do an advanced search on google (type in the domain and then put gen 3 motor or soemthing related that will pull up the posts) you'll probably find quite a bit. Good luck.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD
Click here to support the board
Philippians 4: 6-7
dan42 is offline   Reply With Quote
Old 01-27-2008, 11:20 AM   #3
HavinSomeFun
Still Just Havin Some Fun!
HavinSomeFun's Avatar
He has been quiet. However, when he speaks everyone listens....
a green one with some stuff done to it....
HavinSomeFun is offline   Reply With Quote
Old 01-27-2008, 12:22 PM   #4
Ackattack
Ackattack's Avatar
I'm putting a 5.3L in my truck, so here is what I'm doing.
I'll be using some stainless steel camaro headers. I don't have my transmission yet, so I can't tell how exactly they'll fit, but when I test fitted them, it looks like the collector will be in the frame rails, so they tuck up real nicely.
I'm using an '04 wiring harness, which used drive by wire. So you have to have a special gas pedal and the control box. I believe for cruise control, all you have to do is basically wire up a switch to this little box.
I'll be using an aftermarket speedo, but you may look at "jags that run" website. I believe they have a converter box that will give you a mechanical input for the speedo. The computer needs the electronic signal as part of controling the tranny.
Ackattack is offline   Reply With Quote
Old 01-27-2008, 12:25 PM   #5
killer71
killer71's Avatar
this should answer a lot of your questions http://67-72chevytrucks.com/vboard/s...d.php?t=244448
R.I.P.
Killer 71
10/26/07
killer71 is offline   Reply With Quote
