Old 01-29-2008, 05:54 AM   #1
dan42
dan42's Avatar
installing door seals - adhesive?
What kind of adhesive are you guys using? I was gonna use Barge, but I wanted to see what other guys have had luck with. (I'm installing the seals around the edge of the door).
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD
Click here to support the board
Philippians 4: 6-7
dan42 is offline   Reply With Quote
Old 01-29-2008, 06:39 AM   #2
Fastfun
Fastfun's Avatar
Re: installing door seals - adhesive?
Use 3M weather strip adhesive.
Fastfun is offline   Reply With Quote
Old 01-29-2008, 07:06 AM   #3
clemson71guy
clemson71guy's Avatar
yup that stuff works great
clemson71guy is offline   Reply With Quote
Old 01-29-2008, 07:56 AM   #4
Sweet72
Sweet72's Avatar
be sure to wipe the talc from the new seals, the manufacturer uses it as a release in the molds.
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction.
Sweet72 is offline   Reply With Quote
Old 01-29-2008, 10:20 AM   #5
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Yep the yellow 3m stuff.
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
