Old 01-31-2008, 12:48 AM   #1
drbyrdman
drbyrdman's Avatar
airbags
Anyone just run the airbags in all 4 corners with just a ballvalve or other way. I would like to get 4 bags setup then get the compressor and tank later.
drbyrdman is offline   Reply With Quote
Old 01-31-2008, 12:59 AM   #2
Slmd92DIME
Slmd92DIME's Avatar
Re: airbags
I never have but you can just T your lines together then put a shrader valve on it. Shrader valve is the same thing as a valve stem but with threads on the other side. Just make sure that you dont have any leaks.
My Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=269019
Petitioning *No Regrets* MD/WV
Slmd92DIME is offline   Reply With Quote
Old 01-31-2008, 01:37 AM   #3
HotRodYJ
HotRodYJ's Avatar
Re: airbags
I'd suggest a shrader valve on each bag keeping each of the 4 bags seperated independant of another. When you tie two bags together, like both rear bags, air just moves from one bag to the other when cornering, unless you've got a substantial sway bar to counteract this.
66 Chevy Stepside tandem project
My junk: http://67-72chevytrucks.com/vboard/s...d.php?t=480902
HotRodYJ is offline   Reply With Quote
Old 01-31-2008, 11:50 AM   #4
bedsled71
bedsled71's Avatar
Re: airbags
from experiance.. dont go the cheap way.. do it right the first time
bedsled71 is offline   Reply With Quote
Old 02-01-2008, 02:39 PM   #5
Dinos63
chevy only
Dinos63's Avatar
Re: airbags
both of the last two post, thats good info.if you plan on driving it
CHEVY ONLY... Nothin Else !
Dinos63 is offline   Reply With Quote
Old 02-01-2008, 10:45 PM   #6
drbyrdman
drbyrdman's Avatar
Re: airbags
yep!
Old 02-02-2008, 01:03 AM   #7
snacob14
Re: airbags
Definitely isolate each bag w/a valve of its own, but you can definitely drive it w/out a tank and compressor until you can get them. I've done this for a few months now, but I also keep an air tank in the back just in case.
snacob14 is offline   Reply With Quote
