Old 01-31-2008, 07:02 AM   #1
seanu
Too many projects!!!
seanu's Avatar
Question Drive shaft to rear end, bolts & "caps"
I recently changed out the rear end on my 70 frame to a 71/72 rear end (to convert to 5 lugs)...and noticed after I slid the u-joint back into place and then went to put the bolts and caps back on..that the spacing and I think the bolt size is not the same...
I'm sure I can run to the hardware store and buy the proper bolts..but does anyone sell the "caps"?
thanks
Sean
1995 Buick Roadmaster Sedan
2004 Chevy Trailblazer 5.3L V8
1963 Chevy Biscayne 4D Sedan
1971 Chevy C10 (now have 70 cab & frame)
1968 Chevy C10 (parts for the 70)
1991 Oldsmobile Custom Cruiser (Chevy 355 motor)
1937 Pontiac 8 4D Touring Sedan (in pieces)
Jacksonville, Florida
seanu is offline   Reply With Quote
Old 01-31-2008, 07:22 AM   #2
Luvlegs
Luvlegs's Avatar
Re: Drive shaft to rear end, bolts & "caps"
so the differential yokes are different sizes from the 70 to 71/72?
I guess that's answering a question with another question and I'm not really even doing that.... just clarifying.
"A cat will almost always blink when hit between the eyes with a ball peen hammer"
(you don't always have to state the obvious)
Wear your PPE! You can eat with false teeth but you can't see with a false eye.
1959 Studebaker Silverhawk 350/400
1972 C10 L6 3OTT
2005 F350 - Built - whew!
Luvlegs is offline   Reply With Quote
Old 01-31-2008, 07:25 AM   #3
seanu
seanu's Avatar
Well, unless someone changed out the rear end in the 70 I have with something else..then they must be differernt. But it was definitly a 67-70 rear end I took out.
Sean
Old 01-31-2008, 01:23 PM   #4
seanu
seanu's Avatar
So..does any body sell the u-join caps?
Sean
Old 01-31-2008, 01:49 PM   #5
tll74
"Junkyard Dog"
tll74's Avatar
I believe your dealing with to different yokes. The 70 C10 should of been a Spicer 1310 1 1/16 cap with a 3 1/4 cross and u-bolts. The new rearend probably has a (I think) Spicer 1330 which is 1 1/16 cap with a 3 5/8 cross and bolts and straps. Either change the yokes but dangerous if you over tight the nut or under tighten. Second option use a hybrid u-joint. One half that fits your driveline and the other half fits the new yoke. Most parts guys give the deer in the headlights look when you as for it but it is available. The larger u-joint is commonly found in big block trucks. Hope this helps.
tll74 is offline   Reply With Quote
Old 01-31-2008, 02:53 PM   #6
seanu
seanu's Avatar
Well that sounds like it makes sense...except the U-joint fits into the yoke on the rear end correctly..but the bolts and straps that came off of the 70 yoke, will not fit the 71/72 yoke...
I found a set of u-bolts I had for another yoke..but that won't work..since I need the bolts and straps..
Sean
Old 02-01-2008, 01:53 PM   #7
tll74
"Junkyard Dog"
tll74's Avatar
So.....both yokes use the bolts and straps? And the u-joint fits both of them? If so.......this doesn't make sense, all small u-joint strap type yokes are the same. All 12 bolts 1970 and earlier use u-bolts and 71-up are strap type to bolt in the u-joint. HHMMMMMM
