Old 02-01-2008, 10:29 AM   #1
truckn'
truckn''s Avatar
please help guys!!!
with the help of a another member here at our wonderful site, I found a split 4 barrel intake manifold for my 250 Inline which will allow me to put a 4 barrel carb on it. Will this increase my horsepower or torque any? I need to know if it is worth putting so I can tell the guy that I want it.
truckn' is offline   Reply With Quote
Old 02-01-2008, 11:34 AM   #2
ampsyco
Re: please help guys!!!
remember , too much carb is bad. you need to figure out your displacement, and figure out what your optimal CFM would be. then if they make a 4 barrel in that size.
then you would obviously have to tune it to your application.
ampsyco is offline   Reply With Quote
Old 02-01-2008, 11:41 AM   #3
samwise68
FarmBoy.
samwise68's Avatar
a 4 barrel intake, coupled with a better flowing exhaust, such as a split manifold or headers, will improve horsepower, yes.
These 6's had a hard time breathing, with a one barrel carb and a single 2 inch exhaust, let alone the port design.
as far as a carb, idealy a 390 Holley would work great on a 250, but a 500 cfm carb works well too, it all depends on tuning.
if you haven't, jump over to ww.inliners.org and see if you can find some more info. they're dedicated to 6's,a nd know there stuff.
just my take.
-Sam.
1969 GMC C1500. long fleet.
307. 3 on the tree. 3.07 gears.
Oliver green. Bent and bruised. Daily Driver.
Screw patina... it's a beater...Beaters are cool.
my build thread - Project Homebrew:
http://67-72chevytrucks.com/vboard/s...d.php?t=242993
samwise68 is offline   Reply With Quote
Old 02-01-2008, 12:04 PM   #4
Chevy Fleetside
Chevy Fleetside's Avatar
I will be putting a Holley 390 carb on e bay soon..
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 02-01-2008, 12:10 PM   #5
baddawg65
baddawg65's Avatar
The cheapest and upgrade with the most gain seemed to be converting to electronic ignition. But a 390 Holley, offy intake and headers brought it to life. This is a 292, but I'm sure it will do the same with a 250.
baddawg65 is offline   Reply With Quote
Old 02-01-2008, 02:20 PM   #6
greg64
greg64's Avatar
Hi Truckn,
My 77 has a 250, and I'm using the Offy manifold. The Clifford manifold is really designed for an engine with head work and more than stock cam. The runners are pretty large. I think what really helped was the exhaust, though. The stock manifold must be pretty terrible. I used Stovebolt's cast iron manifolds (not full headers, but way better than stock). As for carb, most of the guys on inliners used the Holley 390. The 500s could be used, but you'd pretty much be running on the primaries. I used a 2bbl 350, and it seems to flow the right amount.
By the way, that's a great looking engine baddawg! 292 with an SM420; that should just about be bulletproof.
Greg
64 GMC Suburban - 283, NV3500, 14 bolt
77 C10 swb - 292, SM465, 12 bolt
greg64 is offline   Reply With Quote
Old 02-01-2008, 02:46 PM   #7
slepysal
slepysal's Avatar
let me know when you do !!
I am running a 2bbl holley on my cliford manifold , with split headers and pertronix electronic ignition runs nice
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes.
"Over, Around or through it... "
slepysal is offline   Reply With Quote
Old 02-01-2008, 03:12 PM   #8
Tomsriv
Tomsriv's Avatar
You could probably get a Holley Econo-miser for next to nothing and they are about 400cfm. The small ports would be great for that motor.
Tomsriv is offline   Reply With Quote
Old 02-02-2008, 12:31 AM   #9
jchav62
1962 C-10
jchav62's Avatar
Let me know too! I have a fresh 250 for the 65. I've rounded up a set of long tube headers and a Clifford 4bbl intake. I picked up a Holley 2bbl with a rebuild kit on the HAMB, but I haven't built it yet. That's what I was going to run for now, but those Holley 390's seem to be the favorite-the way to go.
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
Old 02-02-2008, 01:23 AM   #10
1974k5blazer
thats sweet look'n
1974k5blazer is offline   Reply With Quote
Old 02-02-2008, 12:23 PM   #11
joe231
joe231's Avatar
What is the HAMB?
joe231 is offline   Reply With Quote
Old 02-05-2008, 03:22 AM   #12
NF65Fleetside
NF65Fleetside's Avatar
Originally Posted by joe231 View Post
What is the HAMB?
www.jalopyjournal.com/forum its the Hokey Ass Message Board, typically a hot rod site but lots of inbetween info as well.
NF65Fleetside is offline   Reply With Quote
Old 02-05-2008, 04:45 AM   #13
truckn'
truckn''s Avatar
well this sucks, someone bought the dam thing out from underneath me before I could get it. Now I don't know what I'm gonna do!!!
Old 02-05-2008, 04:53 PM   #14
Heater63
Heater63's Avatar
I hate it when that happens
When you do find another one, don't forget to upgrade your ignition too. Either HEI, or at least a Pertronix's unit. Small 4bbl plus headers plus HEI really wakes the 250 and 292 up!
292 + TKO500
Heater63 is offline   Reply With Quote
