Old 01-16-2003, 10:17 PM   #1
krazy_texan
krazy_texan's Avatar
dash lights
i have a 71 c/20 and when i am driving afterdark when i am driving with my lights on the dash lights will work until i turn on my brights and then the dash lights go out and also when i turn on my blinkers my hole dash flashes. Anybody help me please
Krazy Texan
My Trucks are made with Wrenches not Chop Sticks
1967 GMC 3/4 ton "Johnny Cash"
1990 v1500 suburban
1967 Ford f100 Swb 4x4 "green bean"
GOD BLESS JESUS, JOHN WAYNE, AND THE ALAMO
krazy_texan is offline   Reply With Quote
Old 01-17-2003, 10:28 AM   #2
DARK OLIVE 72CHEYENNE
DARK OLIVE 72CHEYENNE's Avatar
sounds like you have a short somewhere or a naked wire somewhere.mabe just need to trace wires down.
DARK OLIVE 72CHEYENNE is offline   Reply With Quote
Old 01-17-2003, 10:40 AM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Does your fuel guage go crazy when you use the high beams or turn signal? If so, try grounding your inst panel.
Old 01-17-2003, 11:53 AM   #4
Lippyp
English Chevy Owner
Lippyp's Avatar
Check the floor mounted dimmer switch, they get a lot of hammer and damp and mine casued me very similar problems.
Phil
'67 C10 long fleet.
350/TH350, 4 bbl Carter, K&N, Dual exhaust, loads of stuff coming soon
2001 S10 Blazer Daily Driver, bone stock 4 door 4x4 with manual transmission
Lippyp is offline   Reply With Quote
Old 01-17-2003, 02:03 PM   #5
SWINGSAX68
Now the others dig........
SWINGSAX68's Avatar
Hmmmm
Sorry to butt in:
Hey Longhorn mail....how do I ground my Cluster????? My gas gauge goes crazy when I accelerate sometimes and also I think when I do other things.....let me know soon before I go out of town for today friday. How would I ground my Sending unit??? I noticed that some new sending units have like a ground wire on them.
68 Chevy C10 Stepside Black Primer
78 GMC Longbed White
09 Chevy Silverado Shortbed Granite Blue
LOOKING FOR A 67 4 DOOR IMPALA!!!Just like Sam and Dean Winchester!! 'Cause Mustangs are for p^**#$ and you can fit a body in the trunk of a 67 Impala
MEMBER OF THE DRUM BRAKE CLUB
Bachelor of Music in Jazz Studies Texas State University-San Marcos, TX
Certified Music Educator
I hope Mom is up there watching and being my Guardian Angel
"I've got a fever.....and the only prescription.....IS MORE COW BELL"
-The Legendary: Bruce Dickenson
"F#$@ 'em up!!!!!!"
-The Legendary: Rogelio Escobar
TRUCKY LINKS
http://67-72chevytrucks.com/vboard/s...d.php?t=457750
http://67-72chevytrucks.com/vboard/s...d.php?t=461184
http://67-72chevytrucks.com/vboard/s...d.php?t=472848
http://67-72chevytrucks.com/vboard/s...d.php?t=417541
http://67-72chevytrucks.com/vboard/s...d.php?t=477788
SWINGSAX68 is offline   Reply With Quote
Old 01-17-2003, 04:02 PM   #6
lukecp
Formerly yellow72custom
lukecp's Avatar
I had similiar problems, and it turned out to be a bad ground. To ground the panel, go behind the dash and remove one of the little sheetmetal screws somewhere on the back of the insturment panel. Put ring terminal hooked up to a wire around the screw, and put it back in. Make sure to scrape all the old paint off the screw and the panel where the screw goes in. Then hook the other end of the wire up to a ground somewhere. I hooked up mine to the screw on the braket that supports the steering collumn. If the problem stops, you have a bad ground.
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride.
'70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck.
'97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg
lukecp is offline   Reply With Quote
Old 01-17-2003, 04:04 PM   #7
Longhorn Man
Well, if it goes nuts when you accelarate, it may just be your fuel sloshing around (do you have an in cab tank, or blazer style?).
To ground the dash, just run a piece of wire (of decent guage..not little sissy speaker wire) and bolt it to the metal on the back of the panel, and then just ground it someplace on the dash.
Old 01-17-2003, 11:50 PM   #8
SWINGSAX68
SWINGSAX68's Avatar
Thanks Longhorn...I am now with my truck...in San Antonio TX, and my truck "talk buddies" are comeing tommorow, so we have a few things to do to all our trucks!!!!!
Looking to get a Bumper from a 93 chevy pkup to get it straightened out, and looking to install a port-n-polished manifold, some sort of mustang throttle body, and starting to install a nitrous kit on a 91 ford ranger, and a few things to my Rusty.
"F#$@ 'em up!!!!!!"
TRUCKY LINKS
