Old 02-02-2008, 03:31 AM   #1
tk1251k
tk1251k's Avatar
blower fuse
When I turn blower fan fuse blow any speed. What amp is the fuse it has a 20 amp in it now.
tk1251k is offline   Reply With Quote
Old 02-02-2008, 03:54 AM   #2
Luvlegs
Luvlegs's Avatar
Re: blower fuse
I'd look for the short. It shouldn't be popping a 20 otherwise.
"A cat will almost always blink when hit between the eyes with a ball peen hammer"
(you don't always have to state the obvious)
Wear your PPE! You can eat with false teeth but you can't see with a false eye.
1959 Studebaker Silverhawk 350/400
1972 C10 L6 3OTT
2005 F350 - Built - whew!
Luvlegs is offline   Reply With Quote
Old 02-02-2008, 04:14 AM   #3
Wrenchbender Ret
Re: blower fuse
Put a 30 amp. in it. Sometimes these old motors drag a little. If it blows that you have a short or bad motor.
Wrenchbender Ret is offline   Reply With Quote
Old 02-02-2008, 08:07 AM   #4
short step
Re: blower fuse
mine has a 30 amp fuse and 12 ga wire is rated for 25 amps
short step is offline   Reply With Quote
Old 02-02-2008, 09:04 PM   #5
tk1251k
tk1251k's Avatar
Re: blower fuse
I unplugged the blower turned on switch turned on blower and it still blows fuses.A few days ago it it a fuse after driving awile replaced and went on but now constantlly. aia have checked various places for naked wire none yet.
Old 02-02-2008, 10:41 PM   #6
greasy68
greasy68's Avatar
Re: blower fuse
You could try diconnecting everything from the fan motor and running hot(12V) and ground directly to the motor and verify the motor works. If it does you can eliminate that as the culprit. If the fan comes on check the 12V side for a short to ground with a volt/ohm meter. I would guess if the motor is good the 12V side has a short to ground.
Mike
68 C10 LWB midnight blue metallic
307ci, 700R4, HEI
front discs, leaf spring rear
tilt steering wheel, stock ride height, rally wheels,
2007 Dodge Charger(Hemi)
greasy68 is offline   Reply With Quote
