Old 02-03-2008, 12:26 AM   #1
djracer
djracer's Avatar
71 2wd 12 bolt width
I need the actual width from wheel mounting flange to wheel mounting flange. I installed one of these in my uncle's 66 GMC truck and need to go narrower to accommodate a larger tire.
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 02-03-2008, 12:45 AM   #2
pro street 70
pro street 70's Avatar
Re: 71 2wd 12 bolt width
I Used Monti Ss Rear In My 70 Chevy.got 31x18.5x15 On 15x14 Inch Rim. No Frame Mods
1970 chevy short step blown 355
pro street 70 is offline   Reply With Quote
Old 02-03-2008, 01:25 AM   #3
djracer
djracer's Avatar
I have my eye on an 8.8 with rear disc from and exploder. I just need a stock width to reference from. I think we will probably just go with a 12 inch wheel and a drag radial. It already has been converted to trailing arms and coil overs but it has a nasty small block and a muncie!
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 02-03-2008, 01:42 AM   #4
pro street 70
Sounds Like A Sick Truck I Thought About Using A 8.8 Out Of A Mustang But The 8.5 Rear Was A Good Deal.$250 With 3.73 And Aftermarket Axels And Carrier With Only 500mi On It.it Has Lasted 9000mi With Blown 355 Making 450 Hp But I Will Have To See About With The New Motor 357ci 610hp
Old 02-03-2008, 03:22 AM   #5
pro street 70
I Also Have Stock Rear Over Buddys House I Will Get Width For You This Weekend
Old 02-03-2008, 01:23 PM   #6
djracer
djracer's Avatar
you need to scope out the new racing section! Thanks for trying to get a measurement !
Welcome to the board from Alabama!
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 04-20-2008, 04:07 AM   #7
Super73
Super73's Avatar
Anyone ever come up with a width from outer drum to outer drum?
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 04-20-2008, 04:22 AM   #8
uncle
It's 57" from inside of each backing plate,but not sure on the other measurement.
uncle is offline   Reply With Quote
Old 04-20-2008, 04:42 PM   #9
djracer
djracer's Avatar
the explorer 8.8 rear is 60.25 from mounting flange to mounting flange. I bought one from a v8 mountaineer with 3.73's and a posi and 31 spline axles for 275 from the junk yard.
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 04-21-2008, 12:01 AM   #10
Super73
Super73's Avatar
DJ, is that a 5x5 patern or 5x5.5?
I have a lead on a 61" drum to drum 9" for $225. I'm not sure that I want to go disk in the rear.
I asked somone one E-bay that has a 73-87 6-lug 4x4 the width from drum to drum. this is what he gave me.. "measuring it by myself I came up with about 64 1/4 inches from one side to the other where the wheels would seat against the drums, and 42 inches between centers of the spring perches, thank you"
Are these the same width as the 70 1/2 throuh 73 5-lug?
