Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 02-03-2008, 11:55 AM   #351
Big J
Its lookin' like a Blazer!
Big J's Avatar
Re: PO has me PO'd
J that is some cool stuff right there...... Sounds awesome and you can't beat the price, lol..... Good luck with the bucket thing
BAZINGA!
My Build
Big J is offline   Reply With Quote
Old 02-03-2008, 08:54 PM   #352
Chevyman63
Can't wait to retire!!
Chevyman63's Avatar
Re: PO has me PO'd
Wow...great story. I guess you where in the right place at the right time. Good score J. Now lets see that thing together.
2009 4x4 Chevy Crew Cab 6.0
1989 4x4 Siverado (270,000 miles)
1972 4x4 Blazer
2007 Chevy Cutaway 1 ton
1970 Corvette (sons project)
RIP
- CLR 10/11/09
Chevyman63 is offline   Reply With Quote
Old 02-04-2008, 12:01 AM   #353
RustyParts
RustyParts's Avatar
Re: PO has me PO'd
Man oh man, some people can fall into a barrel of crap and come out smellin' like a rose.
1972 GMC Jimmy, 4WD, 454 CI, 350 Turbo, 4" lift, 35" tires
The math teacher said my son "Bubba" could be a mathmatical genius. cause he's got 13 fingers!
RustyParts is offline   Reply With Quote
Old 02-04-2008, 12:04 AM   #354
vtblazer
vtblazer's Avatar
Re: PO has me PO'd
...but who better to have it happen to?
What's this weekend hold for ya Jim?
vtblazer is offline   Reply With Quote
Old 02-04-2008, 01:46 AM   #355
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Yeah,usually when I fall in the barrel I drown
Starting with, pulling a transfer case adapter for a bored member
build spacers for under my motor mounts and seal up oil pan properly
finish up some exhaust work
split my alternator case and rotate it 180 degrees
trying to fit this GMC grille top to the '67 grille
is that enuff yet I know the the radiater looks like sh!t, but holds fluid. If pennies fall out of heaven, by some miracle, before the end of the build I plan to replace it. Radiators.com wanted 200.00, and that just ain't happening rite now...
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 02-04-2008, 06:46 AM   #356
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
I like your other saying better, " Fixing rust is like peeling an onion, ya just keep taking layers away till you hit the good stuff"
SAFETY FIRST
AS usual, off topic
Jim
Old 02-05-2008, 03:44 AM   #357
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Got a little done, hung battery box, put dum dum in the vertical seam because it looked like a prime candidate to hold acid and water. More thinking planning on the '67 grille. I know I'm going to get flamed for cutting a rust free orig. grille [oops, surface rust only, saw it in the pic.], but the part is out there in repro. That's my story, and I'm sticking toit
SAFETY FIRST
AS usual, off topic
Jim
Old 02-05-2008, 04:45 AM   #358
Chevyman63
Chevyman63's Avatar
Re: PO has me PO'd
Way to go.
You got a lot more done than me this weekend. I didn't even unlock the shop today, yet.
Looks good.
1972 4x4 Blazer
RIP
- CLR 10/11/09
Old 02-07-2008, 10:11 AM   #359
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Next step to installing '67 chevy grille in the Jimmy. Hood latch assembly all bolted up as should be, just have to drill one hole in the bottom of the chevy grille that isn't there, so I don't see any problems there. I'm waiting for the headlite buckets and bezel to get shipped in (thanks billsbowtie) to see if there are any problems, but I don't think so... Here's what it looks like so far
first step was to cut off the top and bracket of the chevy grille, I used my electric nibblers since I can control them better, this edge shows so I wanted it strait
SAFETY FIRST
AS usual, off topic
Jim
Old 02-07-2008, 10:23 AM   #360
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Then it was time to cut off the top of the GMC grille since I needed a flange to weld the chevy grille to, I used my cutoff wheel so I wouldn't destroy the small flange that I needed
Then it was just a matter of bolting the flange to the stock location on the upper grille surround of the GMC pc. After fitting I realized I had to move the flange back 3/4", so I had to drille new holes at that location. Vise grips and clecos are what's holding it in now till weld
SAFETY FIRST
AS usual, off topic
Jim
Old 02-07-2008, 10:27 AM   #361
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
I needed the strap clamp to pull the chevy grille closer to the fender
SAFETY FIRST
AS usual, off topic
Jim
Old 02-07-2008, 11:01 AM   #362
Chevyman63
Chevyman63's Avatar
Re: PO has me PO'd
You da man Jim!
1972 4x4 Blazer
RIP
- CLR 10/11/09
Old 02-07-2008, 12:59 PM   #363
Big J
Big J's Avatar
Re: PO has me PO'd
Lookin' good man. Hopefully I get to go over and work on mine tomorrow night.
BAZINGA!
My Build
Old 02-10-2008, 07:00 AM   #364
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
I am officially in the ranks of the two headlite club, sorry to leave all my friends at GMC behind, but it was fun while it lasted. All good things must someday end
Here's pics.
SAFETY FIRST
AS usual, off topic
Jim
Old 02-10-2008, 07:05 AM   #365
Chevyman63
Chevyman63's Avatar
Re: PO has me PO'd
Looks good, you should be in paint by next weekend...right?
OK, we'll give you a little more time.
Starting to look like a completed Jimmy!
1972 4x4 Blazer
RIP
- CLR 10/11/09
Old 02-10-2008, 07:24 AM   #366
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
I think it is now a Blimmy or a Jazer I'm not doing paint till after I drive it awhile, thanks
SAFETY FIRST
AS usual, off topic
Jim
Old 02-11-2008, 12:53 PM   #367
stynchrr
stynchrr's Avatar
Re: PO has me PO'd
That looks cool. Don't worry about cutting stuff. Its all about making it your truck.
stynchrr is offline   Reply With Quote
Old 02-11-2008, 09:03 PM   #368
vtblazer
vtblazer's Avatar
Re: PO has me PO'd
You really running that old school voltage regulator?
Old 02-11-2008, 10:44 PM   #369
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Na, it was on top of the parts pile and kinda shiny, I might use it to hide my headlite relays. I have to investigate the one wire system for my altinator, not sure how to do it yet!
Thanks Stinker, the parts just fell in my lap, so I had to try it
SAFETY FIRST
AS usual, off topic
Jim
Old 02-11-2008, 10:54 PM   #370
jb4short
Damn Yankee
jb4short's Avatar
Re: PO has me PO'd
Don't worry Jim....we have work planned for you soon...LOL
Remember that one piece floor sitting on the frame?
jb4short is offline   Reply With Quote
Old 02-12-2008, 12:51 AM   #371
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
I knew there was a catchLet me know when he gets here! He amazes me with his talent, 'sure I can learn a thing or two. Now that I know that '67 front end work, I plan to buy your repop. I have to check your catalog and see if you make the headlite bezels for the '67
Thanks again for the parts, they look better on my truck then sitting in a corner of your shop...J.
I can't believe it costs 12,000.00 to make a tool for that one headlite bucket. Is that stamping made here or overseas?
SAFETY FIRST
AS usual, off topic
Jim
Old 02-12-2008, 01:52 AM   #372
jb4short
Damn Yankee
jb4short's Avatar
Re: PO has me PO'd
overseas.....tooling is expensive
Old 02-25-2008, 06:26 PM   #373
vtblazer
vtblazer's Avatar
Re: PO has me PO'd
Okay, it's been two weeks since the last update...what's new?
Guys, I saw this build last week and it looks better in person!
That front grill set up is going to be one of a kind!
Looking forward to seeing it completed.
Nice work Jim.
Old 02-27-2008, 03:29 AM   #374
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
First off, before I get into my build update, I would like to acknowledge a couple people for free parts, good deals, and just a general all around help with keeping my head on strait. Not listed in order of importance, and if I left someone out, my apoligees(I don't feel like looking up proper spelling), one of those little icons up there is for spelling, but don't know which one
MaryAnn
VTBlazer
JC
67272
Billsbowtie
ScottH
Chevyman63
BigJ
SpecialK
RustyParts
Tri-Pro/Plus
Tim Christian
67-72chevytrucks board-all you guys
Thank You All, I am where I am on my Jimmy because of your help, conversation, and guidance. There is not a better board on this computer thingy. Use guys are top shelf!!!!
OK, back to updates.
SAFETY FIRST
AS usual, off topic
Jim
Old 02-27-2008, 03:44 AM   #375
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
A little elbow grease, and rubbing compound shined up the anodized alum. after the pic was taken...
So, does a '67 Chevy grille fit into a '72 GMC Jimmy? Yes, with a minimum amount of work!
This was on my porch, after Kurt left. Cool, huh?
Kurt thought this would be a good pic. from my computer
SAFETY FIRST
AS usual, off topic
Jim
