02-04-2008, 01:37 PM | #1 |
Axle and transmission upgrade questions
Hello, this is my first post here.
I just bought a nice 71 k5 that needs some help in order to be all it can be. As you might have guessed by my user name, I am going to install one ton axles and new springs. I am going with the Dana 60 up front. For the rear, I searched this site and others and I have come to the conclusion that I will have to move the spring pads and shock mounts. Is there a version of the 14 bolt that would bolt right in so that I could avoid this step? I know the gov-lok sucks, I am going with the ARB and a disk brake conversion. What are the differences with the later model 14 bolt ff axles and do I need to worry about a carrier break since I will be using an ARB? I can buy a 1991 one ton Suburban from a friend for all the donor parts. Thanks for your help, I know that's a lot of questions but I can't seem to find definitive answers by searching. -Dave
Dave Erickson 1971 Chevy k5 Blazer 4x4 |
02-04-2008, 04:26 PM | #2 |
"Junkyard Dog"
Re: Axle and transmission upgrade questions
The 10.5 14 bolt was never produced with the spring-shock configuration of the 72 and earlier trucks. So you will have to change them. As for your second question, yes there are carrier breaks 4.10-higher and 4.56-lower. The 10.5 14 bolt is the same inside from birth to current except for the inner pinion bearing which was increased in 1988. I have never heard of or seen a 1 ton suburban. Be carefull with the 91 Sub, it originaly would have come with a 9.5 14 bolt semi float. Unless it was a 2wd 454 truck. hope this helps
02-05-2008, 01:12 AM | #3 |
Are you saying there are no suburbans with a 14 bolt FF and D60 combo?
Thanks for the information.
02-05-2008, 01:28 PM | #4 |
I just put a dana 60 rear in my 72 K10.I got the rear end and leaf spring out of a 76 ford factory highboy truck.It fits perfect,only mods are brake line mods,and I had to shim the leaf springs,perfect fit
02-05-2008, 01:35 PM | #5 |
I had heard you could do that. But for me I want one ton gear, as much for the brakes as the strength.
People run 38" tires and don't pay enough attention to their brakes! I want to stop my 38's on a dime. Big brakes + big axles = no worries.
02-05-2008, 01:38 PM | #6 |
I'm pretty sure a 3/4 ton dana 60 and brakes are enough,thats why I changed it over from 1/2 ton
02-05-2008, 01:41 PM | #7 |
I wasn't saying the 60 isn't enough, I just want a 14 bolt, that's all.
60's are good axles front OR rear.
02-05-2008, 01:58 PM | #8 |
I hear ya.Just giving you some options,To each his own.Good luck on your project.
